Results 1 to 10 of 10
Thread: SLAM question
    rabbet's Avatar
    Jun 2012
    Garrison, NY
    13
    SLAM question
    I'm on the on the fourth day and realize I've made several mistakes. Here are the readings from day one:
    pH 7.7 (first mistake)
    FC 4
    CC <.5
    TA 90
    CYA 30
    CH 275
    I think I should have lowered the pH, but it's too late now.
    I had persistent algae, which I assumed was mustard because it was there in spite of correct chlorine and pH levels. It congregates along seams and crack repairs, both of which are a bit rough, and at the right angle corners where the sides meet the floor. So I used the MA number for the SLAM which was 19 ppm, instead of the shock number which would have been 12. So the question is, should I lower the FC to 12 and continue until the FC holds overnight, and then raise the FC to 19 for 24 hours after that? The water is already clear and today the CC was 0 for the first time. I do notice there is a brief white cloud when I brush. Is that dead algae or live algae? I also realized yesterday that I hadn't left the poles, brushes, etc in the pool.
    I'm also wondering if it's foolish to go through all this right before closing the pool.
    I'd appreciate any guidance.
    40K gallon IG painted concrete
    no skimmers
    Triton II sand filter
    2 HP Hayward pump
    Built June 1950
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: SLAM question
    Quote Originally Posted by rabbet View Post
    FC 4
    CC <.5
    TA 90
    CYA 30
    CH 275
    I would say the stuff you are seeing when you brush is either dead algae or dirt/pollen/plaster dust.
    If you have brushed well and don't see algae in the seams like before do an Overnight FC Loss Test (OCLT) to see if you can end the SLAM. The issue of not lowering the pH and conducting the SLAM at MA levels the whole time are water under the bridge.
    Nope, do it now so it's not a bigger problem in the spring.
    Support the site
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: SLAM question
    If your seeing algae in those areas it could be from poor circulation in those areas. Might try brushing there more often.
    I think your ready to try an OCLT. 😎
    Jeff
    rabbet's Avatar
    Jun 2012
    Garrison, NY
    13
    Re: SLAM question
    Strangely, the place where I see the algae is where there is the most circulation.
    no skimmers
    2 HP Hayward pump
    Built June 1950
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: SLAM question
    What is your normal FC target level ?
    Jeff
    rabbet's Avatar
    Jun 2012
    Garrison, NY
    13
    Re: SLAM question
    FC 4
    Quote Originally Posted by tim5055 View Post
    If you have brushed well...
    I never think my brushing is adequate.
    no skimmers
    2 HP Hayward pump
    Built June 1950
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    SLAM question
    For the CYA level of 30 you should target 5-6. That's a little more room so you don't fall below 2. You may have dipped to low with your FC and a little algae starts to form, but you keep it from a full blown outbreak.
    When you open next year I'd go with a CYA level of 40 and target your FC level at 7 and never below 3. 😎
    Jeff
    rabbet's Avatar
    Jun 2012
    Garrison, NY
    13
    Re: SLAM question
    Quote Originally Posted by pwrstrk View Post
    When you open next year I'd go with a CYA level of 40 and target your FC level at 7 and never below 3. ��
    I was going by the chlorine/CYA 'Best Guess' chart and Chemgeek's chart.
    no skimmers
    2 HP Hayward pump
    Built June 1950
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    SLAM question
    Pool Math will suggest different levels that I use in my pool. Never had algae at anytime. My CYA level is 40 and I target FC at 7. That gives me 4ppm wiggle room from FC burn off and swimmers so I don't fall below my min level of 3. 😎
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: SLAM question
    I follow the same process as pwrstrk. During the summer swim season, I target the high end of the FC range suggested by PoolMath . Between sunlight and the warmer water temperatures and higher bather loads of summer, the extra headroom provided by maintaining FC at the upper end of the recommended range has kept my pool algae-free. Haven't had to shock/SLAM in I don't know how many years.
