Thread: Spa Coping - Rolled Edge vs Standard Coping?
    Apr 2014
    NE Texas
    327
    We're digging on Tuesday and one thing that we've been going back and forth on is how we want to have the edges of the spa. Currently, the plan is to have them just like the pool with Oklahoma Flagstone with hand chipped edging. This obviously won't be that comfortable to lean back on, so most likely we'll just be sitting and not leaning back. The rolled edge with the 1x1s look intriguing and much more comfortable.
    Anyone with some experience? Did you do one or the other and have any input?
    Jun 2014
    Frisco, Tx
    36
    Re: Spa Coping - Rolled Edge vs Standard Coping?
    We have the same concern. We're gonna do a rolled armrest under the beam inside the spa. It's a ledge that comes out from the side of the spa about 4" and provides a backrest and armrest so you don't have to lean against the stone. It does take away some space in the spa but my buddy has it and says it's the best thing since sliced bread. Your builder should know how to do this. It was no up-charge for us. Good luck!
    Aug 2014
    marietta/ga
    65
    I love the look of the rolled edge. I would have went that way if I had of found this site prior to starting my build. If done correctly the standard coping won't be an issue though. The idea of the spa is that you sit in very deep, so the coping doesn't really affect you.
    16,000 gallons, IG
    Pebble,Sand
    Jandy 2 speed pump
    Under construnction 8-1-14
    Spa
    Apr 2014
    NE Texas
    327
    Great idea Afluv. We will definitely discuss it with him
    Done! Pool build thread here
    38 x 18 free form, IG gunite with all gunite waterfall/slide/grotto
    18" raised spa, waterfall into pool
    Hayward 3hp Tri Star Pump x 3, 525sqft Swimclear filter, Polaris 280 cleaner
    Hayward LED pool lights, Hayward LED accent lights, 400K BTU Heater
