Thread: Heater recommendation?
    brampton's Avatar
    May 2014
    Brampton, ON
    9
    Hi folks. We had a jandy legacy LRZM that worked great, until the heat exchanger blew. (It came with the house, believe it was not properly taken care of as it is only 2 years old.) Anyway, we're going to replace it and we've decided to go new for warranty reasons. Should we just get the same one and keep the old one for parts down the road, or should we look at something else? I'm not sure if this brand is known to break down or what.
    I'm considering ordering it from here: http://www.poolsuppliescanada.ca/jan...ot-heater.html seems like a good price and I've had great luck with ordering from them in the past.
    Any input would be appreciated.
    Vinyl in-ground pool, around 24,570 gallons (93,000 litres), with SWG, sand filter, gigantic Jandy Legacy heater, Hayward SuperPump. Anything more please ask, new to all this!
    38,275
    Re: Heater recommendation?
    The Raypak heaters tend to get the most recommendations from members who are in the industry and work on them due to the fewer parts and lower failure rates.
    brampton's Avatar
    May 2014
    Brampton, ON
    9
    Thank you, that's just what I was looking for. They're virtually the same price too, maybe I'll go Raypack.
    Apr 2014
    Stony Brook, NY
    159
    Heat exchanger blew in 2 seasons?? Did it crack from freezing?? If not, i would try a different brand. Thats unacceptable.
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Please add your pools info to your signature as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    Have you considered a heat pump ?? Higher initial cost but great payback and savings in the long run.
    https://www.google.com/#q=swimming+p...t+pump+savings
    Solar Blanket, Well Water, Borax Added. 68
