Thread: Can you add Borax in a saltwater system?
    Hi,
    I'm just curious if this is possible and if it is anything to watch out for? I presume just like a chlorine pool but wanted to be sure.
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Re: Can you add Borax in a saltwater system?
    Sure, Borax for raising PH and borates for algae/water feel/and PH buffering are both fine with a SWG.
    If you are adding borates to 30-50 ppm you should get TA in range before adding borates. Other than that there aren't any issues.
    Guest
    Borates are especially useful in a salt pool. That is why there are so many products on the market aimed at salt pools that contain borax!
