Thread: New Build - Keller, TX
    Sep 2014
    Keller
    9
    The excavation was on 8/14.
    The re-bar was put in on 8/15 and 8/16.
    Our first pool. The details ;
    Pool Length 32 ft x Width 31 ft
    Depth 4.5 ft / 9.5 ft
    Surface area 741 sq ft, Perimeter 106 ft
    6 pool returns, auto fill, dual main drains, 2 skimmers and 4 LED lights
    20 ft long, 18" reverse beam
    Spa Length 6 ft x Width 9.5 ft
    Surface area 53 sq ft, Perimeter 27 ft
    6 jets (waterway), contoured seating, dual drains,
    2.5-inch suction, removable fountain and 1 LED light
    Equipment
    IntelliFlo VS filter pump 2-inch suction lines
    3/4 hp Legend pump w/ Racer pool cleaner
    60 sq ft DE filter
    EasyTouch 8 computer w/ indoor remote
    Master Temp 400,000 BTU heater
    1.5 hp Silencer air blower
    Delta UV system and 320 auto chlorinator
    CusePool's Avatar
    Aug 2014
    Friendswood, TX
    91
    Re: New Build - Keller, TX
    Good luck with the build. That looks like a big honkin' pool!! What is the Delta UV system?
    ~18,000 IG/Spa chlorine, Blue Granite Pebblesheen
    Hayward 1.5hp 2-speed Tri-Star Pump, 525sqft Swimclear filter, Polaris 280 cleaner
    400K BTU Heater, LED Lights, PS8 Automation
    Build thread: http://www.troublefreepool.com/threa...s-Houston-area
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Hey awesome. Can't wait to see more pics. Looks like it'll be a cool pool!
    If you're looking for advice, you might research on here about UV systems...Is that auto chlorinator a liquid chlorinator or puck?
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Sep 2014
    Keller
    9
    The Delta UV system uses light to destroy pathogens. I added it primarily for the spa. You still need chlorine hence the auto chlorinator. It's a puck system.
    Here's a picture of the equipment. And yes the heater is facing the wrong direction. Apparently code states that you can't have an operating window within four feet. This was the trade off so that we could move it the requisite number of feet. Although with the easy touch remote and the ability to control the equipment from a smart phone I shouldn't have an issue.
    Aug 2014
    marietta/ga
    65
    Thats going to be nice and very big.
    16,000 gallons, IG
    Pebble,Sand
    Jandy 2 speed pump
    Under construnction 8-1-14
    Spa
