Results 1 to 9 of 9
Thread: to brush or not to brush
    Jul 2012
    Whidbey Island, WA
    397
    So have been brushing "weekly". But is not really rewarding. Never see anything happen. And brushing vertical walls is not easy.
    Will anything super bad happen if I skip this?
    Now of course I never see anything happen when I brush my teeth either but...
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: to brush or not to brush
    The benefits to brushing are that any microscopic algae that may be clinging to the plaster will be scratched open to expose it to chlorine and kill it more efficiently, and it briefly improves water circulation. If you normally have good circulation and stay on top of your water chemistry and never let the FC drop below the recommended range you probably won't be courting disaster if you brush less frequently.
    Love TFP? Become a
    TFP Supporter!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    What about Vinyl Liner Pools? If I stay within the recommended range and do not have any algae problems, do I still have to brush the walls? If so, how often?
    Thank you.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jul 2012
    Whidbey Island, WA
    397
    Thank you, will brush less often.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I brush my vinyl walls maybe every 3 weeks. BUT... I have a robot that climbs walls and does the bottom about twice per week.
    Isolated Spa - 345 Gallons
    38,460
    If you want it to be easier to brush the sides ... get a wall whale brush
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Now you tell me.... More money to spend.
    Support the site
    38,460
    I am not sure I would recommend the XL version, just too big and hard to push. The nylon brush started falling apart on mine after 4-5 years, so I bought a mixed bristle brush and moved the tail over to it
    Jun 2014
    Oslo
    120
    I never brush, but i put to work the robot every other day ( at least ) when I am at the property, otherwise nobody is there to do it. The UV lamp keeps the water sterile and that is all that I need. Water is nice and clean even nobody is there to add chemicals. Still I have an automatic pH controller.
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
