Thread: How to drain
    May 2012
    Ottawa
    13
    How to drain
    First time pool owner and am researching and getting ready to close the pool for the first time.
    Two questions:
    1. Seems silly but, how do I actually drain the pool? I don't have a drain in the pool and my filter doesn't have a backwash feature like most YouTube videos show. Am I stuck going out and buying a submersible pump? I have a pentair sta rite system:3 filter.
    2. I have a liner pool with fibreglass stairs. Anything special I need to do with the stairs or just cover them with the rest of the pool?
    17,000 gal, IG, vinyl, single speed pump, cartridge filter, built 2014, SWG, natural gas heater, city water fill.
    Jacuzzi hot tub, j-280 model, 400 gal, with Clear ray, chlorine system, well water fill.
    Taylor k-2006 test kit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How to drain
    You can buy a cheap sub pump at your hardware store of choice. It will take quite a while but best bang for buck as you can use for years.
    2nd option is to rent a better pump from a location that rents them. Will likely be much faster.
    No special treatment needed for stairs, just cover.
    Isolated Spa - 345 Gallons
    May 2012
    Ottawa
    13
    Re: How to drain
    Thanks!
    buddywiser's Avatar
    Morgantown, WV
    98
    Re: How to drain
    Bruce, you might not have a backwash feature, but your filter could still have a port to go to waste. What kind of filter do you have?
    Also, in the pool, I assume you are talking about not having a main drain, but you could still drain it through the skimmers.
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    Feb 2014
    Central Minnesota
    5,080
    Re: How to drain
    Quote Originally Posted by buddywiser View Post
    That's a good point. If you can get a good seal and keep prime on a vacuum hose from skimmer, you could drain that way on backwash or to waste.
