Thread: Liner Wrinkles
    Apr 2012
    Lynchburg, VA
    90
    Liner Wrinkles
    Anyone ever heard of High Acid causing wrinkles in a liner that is only 4 years old?
    thanks
    PF
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Liner Wrinkles
    Low pH degrades liners so strong acid poured into pool water can pool at the bottom if not poured over a return flow and/or the liner lightly brushed. Is that what you meant by "High Acid"?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Liner Wrinkles
    Wrinkled or puckered liners can be caused by low pH. How long it has to be low to damage the liner I don't know. Liner wrinkles can also be caused by high ground water behind the liner.
    Love TFP? Become a
    TFP Supporter!
    Apr 2012
    Lynchburg, VA
    90
    Re: Liner Wrinkles
    A new client called me, and that was the reasoning given by the gentleman that installed the liner.
    I have not yet inspected it. Either way may be the case.
    Although, he did tell me he has been using 3" pucks so I can't wait to see the high cya. And that also could be why it is wrinkling. I can't wait to share you guys with him.
    Thanks for the input.
