Thread: Replacing bad SWG Controller after pump replacement with intelliflo
    Sep 2014
    Jacksonville, FL
    1
    Folks I need some advice,
    I replaced my pool pumps about a year ago with intelliflo pumps that have their own built in controls. My SWG was Autopilot DIG-220 and with the new pumps, the controller only controlled the SWG (SC-48 cell). I have a 40,000 gallon pool. The cell is about 18 months old.
    Now my Autopilot has failed (power module- no voltage at the controller connection) and I need to decide what to do.
    Buying a new autopilot 220 seems like overkill. What do you recommend as a cost effective SWG replacement that would only control the cell?
    Would I be better off to invest $250 to have my pool pilot repaired?
    John
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Replacing bad SWG Controller after pump replacement with intelliflo
    Welcome to TFP!
    I'm bumping this up in case someone else can help you (this isn't my area of expertise).
    Jun 2011
    Long Beach, CA
    2,790
    I suggest looking into this thread as it might solve your problem, http://www.troublefreepool.com/threa...eck-Clean-Cell.
