Results 1 to 9 of 9
Thread: Chlorine test Taylor k-2006
    Jun 2014
    Bismarck, North Dakota
    28
    Help. I have been using my Taylor k-2006 kit for a couple months. The last couple times I tested, my chlorine test looked "bleached out." Here is what I did with this kit: I used a 10 ml sample. Step 1- add r-0870 powder...2 dippers. It says if the pink color disappears add r-0870. My original sample never turned pink at all, thus it could not "disappear." Do I still continue on adding drops of r-0870? I don't want to waste my drops. I assumed this meant I had no chlorine, but could it possibly be over 10 ppm thus causing it to bleach out? Help please!
    8600 gal/ag/Richwood Round 18 x52 swinn'play pool, Aquamaster sand filter, Waterway pump, install 6/25/14
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Chlorine test Taylor k-2006
    If your sample never turned pink you chlorine is zero. It won't bleach out unless you have some serious high FC levels. 😎
    Jeff
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by Trudy.Riehl View Post
    As Jeff said, you assumed corectly no chlorine. Remember, this test goes up to a FC level of 50, not 10.
    Support the site
    38,354
    I agree ... your FC is 0. It would need to be like >>50ppm for the color to bleach out 2 scoops of powder I think. 10ppm of FC is now high at all.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Use the OTO test kit and if it is clear no chlorine.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    38,354
    Quote Originally Posted by wjr75 View Post
    Does not come with the K-2006
    Sep 2013
    Connecticut
    728
    Just wanted to be sure there's no misunderstanding -- the r-0870 is the powder (not drops), and the K-2006 instructions suggest adding more powder, beyond the initial 2 scoops, if the pink color fades out.
    As others said, if you never even saw a flash of pink as the powder hit the pool water sample, it's highly likely that your chlorine level is 0, so there's no point in putting in more scoops of the powder. For reference, I had chlorine levels around 20ppm recently, and a single heaped scoop of the powder produced a vivid pink color.
    An OTO test kit (readily available, for not much money, at local hardware stores, pool stores, big box stores, etc.) is a useful thing to have on hand -- makes for a good sanity check on chlorine levels.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by singingpond View Post
    Agree!! Now at the end of season look for WalMart to be discounting the already low price to dump them.
    Support the site
    Jun 2014
    28
    Thanks everyone!
