Results 1 to 13 of 13
Thread: Recommendations for bad swg.
    Aug 2013
    Mcallen, TX
    39
    Just found out my swg won't be replaced until another week. It is only an year old and already messed up! Anyone have any recommendations on how to keep FC high enough for the next week. I was thinking of turning it off and adding bleach, is this pretty consistent to what you experts do? Also, will adding bleach mess with any of my other chemicals, everything is pretty much on par at this time except for FC.
    17k gallon pool, pentair whisperflo pump 1hp, Pentair FNS Plus 36, SWG Hayward Turbo Cell 15 40,000g, blue quartz with pebble finish landings/bench, ultra pure water cleaner.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Recommendations for bad swg.
    Quote Originally Posted by jrr View Post
    Yes.
    No
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    38,475
    ^ Pretty much sums it up
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Just make sure you maintain your FC levels according to what your CYA level is. You'll be treating your pool as a non SWG pool now.
    Have you tried cleaning the cell ? 😎
    Jeff
    Aug 2013
    Mcallen, TX
    39
    Yes, the cell is cleaned every three months. I believe it's something with the actual computer because the light turns off.
    About the bleach, any unscented bleach from the store will do???
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep. Just plain regular bleach. No scents or splashless. I use Walmart's brand. 😎
    Jeff
    38,475
    Just check the date code and that there is an actual strength listed ... usually 8.25% now.
    Or see if your pool stores or hardware stores have a better deal on 10% or 12.5% liquid chlorine.
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    Aug 2013
    Mcallen, TX
    39
    Ok, thanks. I'll do that. Do I have to do anything in particular when the salt cell goes back on if I have it on bleach for a week?
    38,475
    Nope.
    In fact, if you are ever expecting heavy use, it is usually a good idea to add a little bleach before and/or after to help take care of the waste.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Maybe just check your PH and adjust if necessary . . Otherwise just let it take over. 😎
    Jeff
    Aug 2013
    Mcallen, TX
    39
    Thanks guys, great advice!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    What is going on with your salt system? If the display is working, but the power light and generating light are not on it could be a $3 fix.
    chiefwej
    Aug 2013
    Mcallen, TX
    39
    The power light and generating light turn off and on, mostly stays off. Called the pool company and they checked it out and said they would just switch it out as a result of being under warranty. The actual computer and salt cell are only like 13 months old. Do you believe you know what it could be?
