Thread: QUAD DE 100 seals
    Oct 2007
    Central Texas
    QUAD DE 100 seals
    Should the large o-ring in a quad de 100 be coated with a silicon based lubricant?
    How about the o-ring for the pressure gauge?
    I assume its teflon tape for the pressure gauge threads?
    I read the manual to disassemble, the grids had been knocked around during shipping, but didn't see any instructions regarding coating the o-rings.
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Mar 2007
    Coastalish 'down easter'
    Re: QUAD DE 100 seals
    Lubing the o-ring helps prevent dry rot and helps is go together and seal a little better. If it's new, it was probably lightly prelubed at the factory, so the first time is a 'freebie', but after that, I'd suggest lubing it whenever you reassemble the unit. When you're applying the lube, don't stretch the o-ring!! What I do is double the ring on itself and gently rub the lube onto the surface.
    I usually just use teflon tape on the pressure gauges.
    Hope the new filter serves you well and long!!
    Luv& Luk
