Results 1 to 14 of 14
Thread: Above Ground Pool w/half deck....Need Cover!
    Sep 2014
    Kansas City, MO
    4
    I have a 24 ft round above ground pool. We just built a deck around half the pool this summer and are now having a huge problem finding a winter cover for this. It's hard to imagine that I have the only above ground pool with half a deck....I am unable to find a cover. Anyone gone through this? Help!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Above Ground Pool w/half deck....Need Cover!
    Welcome to TFP!
    It may depend on how you managed the point where the deck meets the pool. Some people leave a gap specifically for a cover. Can you post a picture of the area where the deck comes up to the side of the pool?
    Casey's Avatar
    SW PA
    10,457
    I just built a deck and put my deck boards about 2-3" below the top rails. I'm getting to old to pull a cover down from under the deck.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    I've seen on the forum exactly what your talking about and they just attached that portion of the cover right onto the deck. I'll see if I can dig the pic up. 😎
    Jeff
    Sep 2014
    Kansas City, MO
    4
    That would be awesome!! Unfortunately, there is no room between the deck & the pool for the cover to go between.....
    Sep 2014
    Kansas City, MO
    4
    I'm having trouble uploading the pictures....there is absolutely no room between the deck and the pool....
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If I had that problem I would just anchor that part of the cover to the deck, on the decking, using tarp straps so it can stretch some. Something like how an inground cover. I would use the same anchors as an inground. Their called pop up anchors.
    http://www.poolsupplies.com/product/...d-deck-anchors 😎
    Jeff
    Nov 2011
    Moberly,MO
    1,010
    look for hurricane above ground pool cover
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Casey's Avatar
    SW PA
    10,457
    Save the image to your computer so you can upload it with postimage.org or photobucket. I use postimgage since imageshack started charging.
    I've had decking over top rail and now under and I much prefer under top rail as it was very easy putting the cover on. Can you zip around the rails and cut some of the decking off to get the cover past the decking and under the pool?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Here's the pic I was telling you about in this thread. See post #12.
    http://www.troublefreepool.com/showthread.php?t=85095
    Jeff
    Sep 2014
    Kansas City, MO
    4
    Thanks so much! I appreciate your help.
    Thanks very much! I was thinking that was what we'd need to do. Appreciate the help.
    Jun 2013
    Newcastle, Oklahoma
    508
    I have similar issue, except my deck is concrete. I hope I left enough room to tuck cover between concrete and pool. Its gonna be close. If not my back up plan is to buy some of those fillable tubes for inground pool covers that you fill with water and use them to weight down the cover on top of the concrete.
    My pool cover just came in at the pool dealer the other day. I havent even opened it yet to start looking at how im gonna do this
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You could use the pop up anchors that they use for safety covers on inground pools if you don't have room to slip the cover between the concrete and the pool. You put the anchors in the concrete and then using a trap strap to attach the cover to the anchor.
    Just a thought. 😎
    Jeff
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by pwrstrk View Post
    Just a thought. 😎
    yeah, i have thought of those too. actually ive been kicking myself for not thinking about putting some tie downs in the concrete when it was curing...
