Thread: What is this gasket/oring called??
    Feb 2014
    dfw tx
    67
    Found a problem and the gasket/oring wasn't included in the kit that I bought Can't figure out what its called or if its available on amazon can anyone help its going onto a challenger 1hp pump its the gasket attached to the motor on the pic below
    Can't find it on amazon or online but i believe it may be causing my small leak.
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: What is this gasket/oring called??
    Looks like a foam or paper gasket. but based on the parts diagram that's not a place where water should be. Have an image of the one you have?
    http://www.inyopools.com/pool_parts_...hallenger.aspx - is this the same pump you have? images of the motor are different.
    water should stop @ part #2 (seal plate)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Feb 2014
    dfw tx
    67
    Quote Originally Posted by mrcarcrazy View Post
    Here is the pic of it back onto the pump there cracks all over it
    Here is a pic of the seal I replaced maybe 3 or 5 days ago.
    16k gallons
    1hp pump
    Built in 2000
    38,507
    I am not sure why you would need that rubber seal on the shaft.
    Is there a large chunk missing from one of the 3 fins in the last picture?
    Feb 2014
    dfw tx
    67
    ya didn't notice it earlier but yep seems to be a missing chunk. Tried to reinstall it just to have band screw strip yay.
    16k gallons
    1hp pump
    Built in 2000
