Results 1 to 9 of 9
Thread: Aquapure 1400 error code 125, 194 (and other problems)
    Jan 2010
    Northern Virginia
    282
    My Jandy Aquapure 1400 SWG is on it's 4th season and up until now it's been working fine.
    A few weeks ago, I noticed the pool water getting cloudy and then noticed the control box was reading "service" and it gave me a couple error codes (125, and 194 I believe). The 125 code told me that the cell needed cleaning - so I cleaned it and everything seemed to go back to normal. (I didn't see any scale build-up or anything unusal before I before I cleaned it, by the way). The 194 error code is not even listed in my manual!!
    This past weekend, I again noticed the water getting cloudy and checked the dispay and I got the same error codes (125, 194) so I cleaned the cell again. The display also read "Service". I checked it last night and the situation was the same - - - 125 and 194 error codes and "Serivce" on the display and the "service" light was on. (Interstingly, at one point the display showed that everything was normal - no error codes, no service lights on and no "Service on the display. But a few minutes later it reverted to flahing the error codes and saying "Service")
    Questions:
    1) Does all this mean that my cell is at the end of its life?
    2) If so, can I just replace the cell itself (the thing the water flows through) and leave the electronic display box as is, or does that have to be replaced too?
    3) What the heck does the 194 error code even mean?!?!?
    4) If I do replace the cell, should I (or can I) go up to a larger size? (my pool was caluclated by the builder at 30K gal, and the Aquapure 1400 is supposed to be able to handle 40K gals, but I wonder if maybe my pool is a little bigger than calculated and I'm pushing the upper limit of the cell. I've been running it at 75% all summer, but in previous years I kept it at 30, 40, 50%)
    Thanks!
    Bart
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Jun 2011
    Long Beach, CA
    2,784
    Re: Aquapure 1400 error code 125, 194 (and other problems)
    Error code 194: Cell Current is 85% lower than desired and cell voltage above 19V (Generates 125 code – Cell dirty or needs replacement). Since the cell is clean it looks like the cell needs to be replaced. I would buy a cell and sensor combo, you don't need the box.
    Jandy does not make a cell that is larger than the one you have.
    Jan 2010
    Northern Virginia
    282
    Thanks ping!!!
    How does the current get lower than it's supposed to be? Is that because the cell is old or dirty?
    Jun 2011
    Long Beach, CA
    2,784
    Both of those conditions can cause that. When my cell started to go out, I was getting those errors off and on for a week and then it completely failed.
    What is the box displaying for salt, and have you tested the salt independently?
    Also, check to make sure that your cell cord is making a good connection.
    Support the site
    Jan 2010
    Northern Virginia
    282
    The box is displaying 3.1 for salt..................3100 ppm. I don't have a test kit for salt level. I haven't added any salt since the pool was opened, but I haven't had to add too much water either.
    Jan 2010
    Northern Virginia
    282
    When replacing the unit, do I just replace the cell (the "pipe" that the water flows through) or do I have to replace flow/salinity sensor too (the round disc with wires attached at the bottom of the cell)? Or is it possible the possible that I just need to replace the flow/salinity sensor?
    The cell alone is about $450
    The cell and the flow/salinity sensor is about $500
    Smart money probably says replace them both since it's only an extra 50 bucks, but I'd really love for someone to tell me that I ONLY need to replace the flow/salinity sensor for 50 bucks!!!
    Check the salt level before deciding what to do.
    Also, make sure that the cell cord is good.
    Support the site
    Jun 2011
    Long Beach, CA
    2,784
    If you have to buy a cell make sure you buy the cell and sensor together. The sensor is about $200 bucks and they do fail.
