Thread: Best Way to Heat Pool During Winter - Arizona
    Jun 2014
    Chandler, Arizona
    88
    My daughter's birthday is in November and we would like to throw a birthday pool party. Any suggestions as to the best way to heat a relatively large, inground pool? I've read many reviews involving floating solar rings but they vary in terms of their effectiveness. Any advice is appreciated.
    28k gallon in-ground pebbletec pool w/waterfall and grotto feature
    Triton II sand filter
    "The Pool Cleaner" 4-wheel vacuum
    1.5hp main pump; 1.5hp water feature pump
    Taylor K2006 test kit
    38,471
    Re: Best Way to Heat Pool During Winter - Arizona
    You will need a gas heater to get any reasonable heat added to the pool at that time of year. And a cover to reduce heat losses to evaporation.
    Jun 2014
    Chandler, Arizona
    88
    Gas heater? Can you elaborate or post a link to an example of your recommendation?
    Jun 2014
    Oslo
    120
    It is possible to use also a heat pump. With the new ones you will get 4-5 kWh of heat for each kWh taken from the mains.
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
    38,471
    Google "pool gas heater" ...
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am going to mention solar heat as a possible option if you have enough area for collector, although as the available amount of sunlight drops off rapidly in November a lot depends on the exact date and weather conditions. Last year we hosted a birthday party of a neighbor's 16 year old kid in the middle of November (15th o 16th) with only solar heat and while the water was a bit cool at about 77 degrees, the kids did not mind. (The pool was still at 82 on Halloween) Of course we are in a slightly different climate and have an indoor pool which makes a difference.
