Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Whats your fill water test results?
    Jun 2013
    East TN
    309
    I am curious to see what others have for fill water and whether its city or well water.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Whats your fill water test results?
    My water last winter. Wonder if it has changed... I doubt much.
    FC: 0
    CC: 0.5 ppm
    CH: 325
    TA: 280
    pH: 7.2
    Isolated Spa - 345 Gallons
    Jun 2013
    East TN
    309
    If you have city water then you must be the guy furthest away from the treatment plant since you dont have any FC. Here is mine on city water.
    FC: 1
    pH: 7.4
    TA: 200
    CH: 200
    CYA: 0
    We are at the end of the water line, at least on this side of the treatment plant.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    City water here.
    Last results were:
    FC 0
    CC 1.5 (They use a monochloramine for sanitation here)
    pH 8.0+
    TA 280
    CH 50
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by easttn View Post
    FC: 1
    pH: 7.4
    TA: 200
    CH: 200
    CYA: 0
    We are on city water and we are pretty far down the line. I'll probably test it again soon just for giggles and grins.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    We have city water:
    FC: 1
    pH: 6.8
    TA: 10
    CH: 25-
    CYA: 0
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jun 2014
    860
    Best to take a water sample from a spigot outside the house and closest to the main line running into your home. That eliminates sources of contamination from the house piping. I'll grab a sample later today from the spigot that my auto fill line is hooked up to as that will be the most accurate sample of what goes into the pool.
    Aug 2014
    Seminole, FL
    92
    Here's mine in sunny Seminole, FL today, city water.
    FC <1 very very slight pink tinge after dpd powder
    CC 0
    pH 7.9
    TA 170
    CH 200
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Jun 2014
    860
    Quote Originally Posted by SunnyOptimism View Post
    Eastside Tucson, Water District #7
    Let 10 gallons run from spigot that auto fill is attached to, then tested a water sample -
    FC 1
    CC 1
    TA 120
    CH 250
    pH 8.0+
    Obviously no CYA. Would have to check with Tucson water website to see what TDS, nitrates, phosphates and metals are but I know they always test below EPA regs for those.
    Feb 2014
    Central Minnesota
    5,080
    Tested again today.
    pH - 7.3
    FC - 0.5
    CC - 0.5
    TA - 250
    CH - 350
    Jun 2013
    East TN
    309
    You guys that have low CH levels, do you have water softeners?
    Jun 2014
    860
    Water samples should be taken from an external spigot near the water inlet to the home, not from a tap. That would avoid confounding results caused by softeners. External spigots are usually plumbed separate from the other water lines in the house to avoid watering landscape with softened water.
    Feb 2014
    Central Minnesota
    5,080
    I do have a softener but like Sunny said, took my sample from outdoor spigot where I normally fill pool. Without the hose, ran for a minute before sampling.
    Mar 2010
    Spring, TX
    1,082
    Fill Water Results
    pH FC CC TC CH TA CYA
    8.2+
    0.5
    1.5
    2.0
    25
    400
    0
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Jun 2014
    860
    Quote Originally Posted by mynewpool View Post
    Fill Water Results
    pHFCCCTCCHTACYA
    8.2+
    0.5
    1.5
    2.0
    25
    400
    0
    HOLY TOTAL ALKALINITY, BATMAN!!!
    Jun 2013
    East TN
    309
    Better a TA of 400 than a CH of 400.
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    City water (Comer GA)
    FC 1
    CC 0
    CH 75
    TA 60
    PH 7
    Hope you guys don't mind, but I put this in a spread sheet. I added all of the posts above this one already (If for any reason you don't want your results included, let me know and I will be happy to delete). If I get enough records, I might plot them on a map or something.
    Anyone is welcome to add more entries with this URL:
    https://docs.google.com/forms/d/1rvU...Ac7UA/viewform
    And you can view all of the raw data here:
    https://docs.google.com/spreadsheets...#gid=375112876
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    Jun 2013
    East TN
    309
    Quote Originally Posted by Shirker View Post
    As long as you dont give my name to google. Ha.
    Jul 2012
    Central Texas
    436
    Why is that? For pool water, isn't it more problematic to have that high of a TA then it is that high of a CH? Or are you saying that because it is easier to reduce TA then to reduce CH?
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
  20. Back To Top    #20
    New Brunswick Canada
    819
    Eastern Canada is where I reside, here is our fill water
    CYA 0
    FC .5
    Ph 7.0
    CH 20
    Alk 20
    And will test high in iron and copper, a lot of staining occurs in my area. Dearly looking for the best metal remover.
    What are opinions on expensive pre filters?
