Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: k2006 test kit
    May 2014
    Liberty hill, TX
    25
    k2006 test kit
    My wife took my water to the local pool store they came back with a weird FC and CC numbers and said my borate level was low 7 ppm and my hard water was high 400 and my copper levels were low everything else was pretty close. I filled up the pool with well water witch is a very hard water.
    FC They had 3.84 ppm i had 5.0
    CC they had 3.99 ppm i had .05
    I have seen many post in the forum about this problem with pool stores. So just to make sure if my CC is too high will it or will it not bleach the test out giving me a low number or should I just start trusting my testing. And should I stress about the copper and hard water.
    IG 15000 gal 16x30 Gunite w/stonescapes-mini-pebbles (Midnight Blue), Hayward PROLOGIC Automation panel, Hayward 2HP VS pump, Hayward Swim Clear C3030 cartridge filter ,LED 5 color light, Pool Shark Electric cleaner, pool build finished on 8/15/2014 k-2006 test kit no spa or heater
    http://www.troublefreepool.com/threa...orth-Austin-TX
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: k2006 test kit
    Quote Originally Posted by jquinney View Post
    Are you sure the 3.99 is CC and not TC? Pool stores like to give a Total Chlorine number.
    In any case, ignore them. Trust your testing
    Support the site
    Sep 2013
    Connecticut
    728
    Re: k2006 test kit
    How did you get a value of .05 for CC? Depending on your water sample size, you'd expect to get multiples of .2 ppm or multiples of .5 ppm for your test result.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    38,295
    Re: k2006 test kit
    Post up a full set of YOUR test results if you would like overall comments.
    There is nothing you can do about high CH besides replacing water and 400 is not that high. Ideally you want your copper level to be 0.
    May 2014
    Liberty hill, TX
    25
    Re: k2006 test kit
    is says Total Chlorine 3.99 ppm recommended 2-4 ppm
    38,295
    Re: k2006 test kit
    We do not put much stock in what they recommend. Are you going to follow their recommendations or the TFP recommendations?
    You can not know what the required FC level is until you know your CYA. See the FC/CYA Chart and the Recommended Chemistry Levels.
    May 2014
    Liberty hill, TX
    25
    Re: k2006 test kit
    my numbers are in the red the .05 should be in combined chlorine CYA is 35
    Im going to use TFP but I want the pool to balance out from the new build first before I switch. And before I use a new system I want to be sure I know how to test correctly before I mess with a new system, does that make sense.
    May 2014
    Liberty hill, TX
    25
    Re: k2006 test kit
    I did the smaller test because i new the chlorine was high
    38,295
    Re: k2006 test kit
    What does your CYA test say? And I do not know what "I did the smaller test because i new the chlorine was high " means.
    Honestly you would have less confusion if you just took control yourself. Trying to match yours and their test results is an effort in futility and will just make you crazy.
    Jul 2014
    Hope Mills, NC
    567
    Re: k2006 test kit
    Your numbers and theirs are quite close.
    What is it that youu are actually concerned with?
    All you need to do is up the CYA a bit and keep the FC close to where it is. Other than that, nothing really screams out as horrible.
    Note: This is assuming that you did your testing per the instructions and are reading the results correctly.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2014
    Liberty hill, TX
    25
    Re: k2006 test kit
    I think it makes me second guess myself more then I should the last thing you want to do is screw up the pool
    thanks for the help........
    Sep 2013
    Connecticut
    728
    Re: k2006 test kit
    If this is in response to my earlier question, I was simply suggesting that you may have the decimal point in the wrong place. If you used 10 ml sample size, and added one drop to make the pink go away on CC test, then your level would be .5 rather than .05.
    Overall, as another poster pointed out, your results don't look alarming, and they also don't look tremendously different from the pool store numbers. So, in response to your question in the original post, no reason to think that the test was bleaching out because of overly high chlorine levels or anything like that. You'll note that the pool store numbers show total chlorine at 3.99 and free chlorine at 3.84, which means a combined chlorine (CC) number of .15 -- also quite low, like yours.
    Relax, play with the K-2006 some more, and have confidence in your own test results.
    As far as the CYA test (the hardest-to-read of the bunch), the K-2006 has a pretty limited amount of that reagent (about 6 tests worth). If you want to practice and refine your ability to read the test, just pour the sample back out of the tube with the black dot into the original squirt bottle; then drip back into the black-dot tube and see if you can tell when the dot disappears (with sun behind your back, and the tube about at waist level). Repeat as often as you like. That way you can get more confidence with that particular test without using up all your reagents.
    Jun 2014
    860
    k2006 test kit
    I can't tell from my Tapatalk app, but a VERY important question not asked is this - what is your method of chlorination?
    Most new builds will often have the PB using solid chlorine tablets. If that is the case, you need to get away from those as soon as you feel comfortable enough with the TFPC Method.
    In order to practice TFPC with the least amount of hauling on your part would be to get some form of automated chlorine system - SWCG or Stenner pump. You can do jug dumping of bleach for a while, but it gets old fast and life has a way of interfering with daily pool care. A little automation goes a long way.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Re: k2006 test kit
    the pool store printout that says your copper is too low is pretty funny. the TFP method says anything above 0.0 is too high!
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Jun 2014
    860
    Re: k2006 test kit
    Quote Originally Posted by poolnoob.ca View Post
    Yep....sales & marketing for Cu-based algaecides and "mineral" packs...cuz god-forbid your pool doesn't have "minerals" in it
    Jun 2014
    860
    Re: k2006 test kit
    Hahaha...and no phosphate test!!! Doesn't that pool store know all the money it's letting walk right out the door by not testing for those pesky phosphates!?!?!?
    Quick, someone call a PhosFree salesman and send him over there lickity-split!!
    jv92red's Avatar
    Mar 2013
    SoCal
    117
    Re: k2006 test kit
    Quote Originally Posted by SunnyOptimism View Post
    Forget making money on phosphates, pool store is making plenty of money telling people they can run their CYA up to 150 ppm max and still be in a recommended level. That's because while they would need a FC level (since it's off the FC/CYA chart I'm guessing) around 15-20ppm to keep the algae away at that CYA level, pool store FC recommended level would of course never need to be anything over 4 ppm so pool store will be making a ton of money on shock powders and algaecides when the pool is constantly green.
    15'x35' IG 16,500 gallons w/attached raised 18" spa continuous coping w/underneath spill and ledger stone wrapped, NPT mini pebble aqua blue w/2x pigment & abalone shell finish, 2"x24" travertine coping, 3x Jandy Color LED lights (2 in pool), Jandy Flo Pro 2HP VS pump, Jandy LXI (low NOx) 400K BTU heater, Jandy CL460 cartridge filter, Jandy AquaPure Ei SWG, Jandy Z4 automation with iAqualink and remote poolside PDA, 1,300 sqft Belgard Catalina paver deck with drainage, fire pit that matches the spa with travertine coping and wrapped in ledger stone, Elitewood insulated patio cover, Vinyl gates, back vinyl fence coming soon...
    TF-100
    Jun 2014
    860
    Re: k2006 test kit
    Quote Originally Posted by jv92red View Post
    Yeah, the willful ignorance is practically criminal....
    May 2014
    Liberty hill, TX
    25
    Re: k2006 test kit
    I have a big problem going with the full TFP method I have Oklahoma stone on a swim step and the coping. So I'm concerned the SWG would ruin that stone.
  20. Back To Top    #20
    May 2014
    Franklin, NC
    9,184
    Re: k2006 test kit
    One store I went to said 200 was still OK
    Support the site
