Thread: Recommend Dolphin Pool Cleaner please
    Oct 2007
    Parkland, FL
    752
    Hello,
    So I've had a few Robotic pool cleaners, Dolphin Diagnostic, Aquatron Cobia, and blue diamond remote control. Since the blue diamond died, I've been looking at getting the Dolphin primal X3 as I don't really want to spend a fortune again. We have an offer in on a house and the pool is smallish, I've attached a photo. My concern is do I need a full top of the line for it to clean the sun step or will none of them clean that anyway?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    Re: Recommend Dolphin Pool Cleaner please
    I have a dolphin Nautilus and its a very good cleaner. Pretty much bottom of the line for Dolphins but it does an excellent job.
    It doesnt clean the tile line very well for absence of a float handle,. but it tries. It climbs the walls and does the bottom, so I can manage the tile line.
    Pretty much none of the robots will be able to make it up to the sunshelf no matter how much they cost. And if they did make it up there, they would crawl right off of it.
    I dont know anything about the X3, but I believe some folks here have them. Maybe someone will chime in.
    Divin Dave,
    Jul 2014
    Peoria, IL
    389
    I have an m4 and she will climb the walls and my swim out steps without a problem. Have to give her a toss back in sometimes
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
