Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Jandy VS FHP 2.0
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Jandy VS FHP 2.0
    Anyone running this pump, I am thinking of upgrading my single speed..My automation is IAqualink. Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Jandy VS FHP 2.0
    Anyone have any thoughts on this upgrade...Thank you
    Autopilot SWG
    38,521
    How much does your electricity cost? Do you actually need more than 2 speeds?
    Would be cheaper to just replace the motor on your existing pump with a 2-speed version ... run high for the spa and low for filtration.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    First 1000 kWh @ 0.0067, then 0.0039 kWh after that. I am not to sure on how they read that. Thanks.
    Autopilot SWG
    38,521
    That does not look right ... would be VERY cheap. It needs to be > $0.20 per kWh before a VS makes sense over a 2-speed.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Sorry here it is 1st 1000 kWh @ 0.0600770 over jumps to 0.071590 that is non fuel
    Fuel is 1st 1000 kWh @ 0.029470 then 0.039470.
    Hope this helps.
    Maybe that is cheap...
    Autopilot SWG
    38,521
    So $0.09 to $0.11 per kWh ... yeah a VS does not make financial sense over a cheaper 2-speed motor.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Thank you, could a 2 speed be controlled by IAqualink setup?
    Autopilot SWG
    38,521
    Most automation systems will control 2-speed pumps ... usually need to have 2 relays available. I do not know anything about the Jandy systems though.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I have the "E" stealth version of that pump and love it. Works great with all my Jandy automation. Quite honestly my setup is only using 2 speeds, however I have not noticed a big rise in my electricity bill while using it. You will probably have to do the math and compare the costs of that VS pump and a 2 speed.
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Quote Originally Posted by skylar18 View Post
    Is that a VSP pump, or 2 speed? The pump is the only thing that is left on the upgrade, I have a Pentair WhisperFlow single speed now...makes a lot of noise when running..
    Autopilot SWG
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    It is VSP. Very Very quiet. I have to be standing right next to it to hear a very faint hum. Now my Polaris Booster pump.....Not so much. It is not real loud, but much more noise than the E-Pump.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Ya I might go with the Jandy VSP.
    Autopilot SWG
    38,521
    The 2 speed is also very quiet on low. You have to decide if the premium is worth the cost even though you may never recoup the extra $.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    If I could just take the 2 speed install it, and hook it up to my IAqualink and set the speeds from it, but was told would require more work, while the vsp would just connect . The few extra dollars is not a problem, not to sure with Jandy .
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Thanks everyone for the help...
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I just bought the Jandy 2.0 VSP FHP, got a good price on it...now to find an installer so I don't void the warranty.
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I'll tell you Jandy tech really hate to give any help, I just wanted to know if my iAqualink was compatible they said I should get the info from a licensed pool installer. Just a yes or no would of done it.
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I just spoke to my pool installer and he said if I didn't buy it from him, even if he installs it, I would still lose the warranty...is that so?
    Called Zodiac, and they said as long as I have a purchase slip for it they warrant it for a year. Which is good..
    Autopilot SWG
  20. Back To Top    #20
    38,521
    Maybe. You would have to ask Jandy.
