Thread: Auto pool covers
    Aug 2014
    Pittsboro, nc
    3
    Auto pool covers
    We are having a pool installed in the next few weeks. It will have an auto cover...do all auto covers require the use of a pump on the top of the cover to remove the rain water etc? The sales person says not, but I have not been able to find any online literature to support this. Many thanks.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Auto pool covers
    We have a Coverstar auto cover and need to use a pump on the cover. We have a little giant pool cover pump. If you buy one make sure the one you get has the lower water level auto turn on transducer I think they are called. Also the the little giant we have has a separate plug for the auto turn on portion that the main pump plugs into. I like this because you can manually turn the pump on regardless of the water level. I use this feature when I get water on the cover after the storm and open the cover collecting all of the remaining water in the cover leaving the cover open a few feet. I then pump all the remainder water off before opening it all the way.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2014
    Peoria, IL
    389
    I have a rule cover pump that came with my APC cover. Came with it. Lasted 3 years. Bought another one off of eBay for $50. Worth every penny. And every auto cover that I have heard of needs a pump. If you get too much water on there it will not want to open correctly.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Aug 2014
    Pittsboro, nc
    3
    Many thanks for your comments...
