Results 1 to 13 of 13
Thread: Ready to SLAM, buit is CYA too low?
    Aug 2014
    Tampa
    37
    I just got my test kit and 4 jugs of chlorine, ready to SLAM for a couple/few days to get rid of algae. Should I bring the CYA up to a certain level before I start? I could still see the dot with the vial full...
    SeaCorey
    IG concrete, 14'x24', 11k gal
    Paper cartridge filter, 1hp 2-speed pump soon
    [8] Heliocol panels harvested from a solar electric customer
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you could get it to 30, that would be great. You can start to SLAM as it's dissolving or wait till it's all dissolved. No need to test for it, as it takes up to a week to fully register. Just assume it's there. Your shock level is 12 for a CYA of 30. You can go a tick or two higher.
    What test kit did you get ?
    I would also get more bleach. I'd start with a dozen jugs. How bad is the water ? Pictures are great !!
    Review the SLAM process and follow it to the T. 😎
    Jeff
    Aug 2014
    Tampa
    37
    Re: Ready to SLAM, buit is CYA too low?
    Can I put like 9 3" tabs in the inline chlorinator and open it all the way up to up the CYA?
    Oh, and thanks for such a quick reply, gonna go take a pic or 2.
    Aug 2014
    Tampa
    37
    Partially brushed to show debris on bottom.
    38,305
    That is a very slow way to get the CYA up and while waiting, you are going to lose a lot of your FC to the sun while you SLAM.
    Each 8 oz trichlor tablet would add ~5ppm of FC and ~3ppm of CYA to your water so 9 tablets would get you close, but how long is it going to take to get them all dissolved? In addition, your FC may get to be too high and your pH is going to crash low if you can get them to dissolve quickly.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ahh, she's nice and green.
    I prefer the granular stabilizer route, but you could do the pucks as long as you know how much each puck is raising CYA, FC and lowering PH. Pool math at the bottom of the page, Effects Of Adding Chem's, will tell you what each puck is adding to your water. This won't be the best route to take IMO.
    Again I think it's easier to just go the granular route for your CYA addition. That's what we usually reccomend.
    Jeff
    Aug 2014
    Tampa
    37
    SO that's the granuals from the pool store?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes. Walmart also has the granular stabilizer. 😎
    Jeff
    Aug 2014
    Tampa
    37
    Yeah that green's almost all on the bottom - until the brush gets wet...
    Aug 2014
    Tampa
    37
    OK great, thanks!
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Definitely get more bleach! You're gonna need it soon with a green monster!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Aug 2014
    Tampa
    37
    I'm using 2.5 gal 10.5% pool store jugs, how many am I likely to go through? How many jugs to raise 10k-12k gals up to 10ppm?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Hard to say how much chlorine you'll use to clear it.
    Use Pool Math to figure out how much chlorine to add to get to your shock level. Just plug your numbers in. 😎
    Jeff
