Results 1 to 9 of 9
Thread: Little Holes in pool
    Jul 2012
    Greenfield, Mass
    10
    After about a month of watching my water level it seemed clear that there were holes in my above ground pool, small ones. My Water level was dropping about an inch every three to four days. The reason I say small ones is because I can’t find a leak anywhere inside/outside the pool,,,,,, the intake, exhaust hoses and filter all check out, not the problem, no leaks,, checked the seams of the pool nothing,,,,,Hired a “pool guy” he claims to have found 4 small pin holes near the edge of the pool (where the liner meets the wall) I still notice a loss of water, it’s at a much slower rate, this pool is stressing me out
    My question is, should I cover the pool knowing it will lose some water over the fall/ winter and try to (fill when needed) ? or have the liner replaced?
    24’ -52 “ above ground pool, liner is @3 years old,
    15,000 gallons
    type filter DE
    AG
    Under a year old, June 20th 2012
    Aug 2013
    south east Arizona
    200
    Re: Little Holes in pool
    I can lose an inch a day just from evaporation, but I am in Arizona. Has the weather been dry?
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    Jul 2012
    Greenfield, Mass
    10
    Thank you for responding,
    no, I don’t believe that evaporation plays a part in my pool water lowering,, I’m thinking more of very small ant holes in the liner, the “pool guy” probed my pool with electricity and found 4 holes,, I do find dirt in my pool often, (I don’t believe the dirt comes from anyone using the pool), I think it comes through my liner, I’m nervous to close the pool for the winter with this happening,
    Matt
    15,000 gallons
    type filter DE
    AG
    Casey's Avatar
    SW PA
    10,457
    I would be nervous too as you could lose your water and have the pool collapse. I would try to find the holes if you're losing that much water. If you're getting dirt in the pool with no one swimming, it would lead me to believe the holes are on the bottom. You'll need someone to actually swim the length of the pool patiently and carefully to see if they can see them and patch them. If all else fails, then you may need a new liner but I wouldn't cover it losing all that water.
    It's a hard decision so late in the season. What would I do? I'd get in and swim the bottom looking for holes and patch as I go and keep an eye on water level for the next week. If that didn't help, I'd seriously consider a liner replacement just to save the pool from collapse.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by Matt k View Post
    ... the “pool guy” probed my pool with electricity and found 4 holes....
    Matt,
    Don't mean to hijack your thread, but I'm intrigued by finding a leak w/ electricity. Got any idea how that works? I've got a leak, too, and this sounds like a novel way of finding leaks.
    Thanks!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Jul 2012
    Greenfield, Mass
    10
    Casy
    I’ve swam the pool millions of times, patiently looking,,, nothing,,,, I’m gona roll the dice and pack it up for the winter and keep an eye on the pool level till the spring!!
    Had to pull the triger, I was running out of time!!!!
    CUTiger,
    Kind of like looking for gold in the ground with a metal detector,,,He has a battery , he takes the positive and negative and grounds them next to the pool inside the dirt,,,he then takes the other end of the negative, places it onto a metal plate lays it into the pool about a foot down,,,the positive it attached to a pole which acts a probe, he wears a set of head phones and listens as the probe hums,,,when the hum becomes loud, a hole has been found!
    15,000 gallons
    type filter DE
    AG
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Wow, that's something! I used to think leak detection was an art. I guess it can be a science.
    Thanks, Matt!
    TF-100 test kit.
    Jul 2012
    Greenfield, Mass
    10
    I don't think I explained it correctly/Clearly but you kind of get the "gist “of my ramblings!
    Good luck!!!
    15,000 gallons
    type filter DE
    AG
    Jul 2011
    N. Ga Mountains
    151
    I had a 1 year liner and ended the year with tiny pin holes in it. It was ants. When we put in the new liner we first treated the ground under and around for ants. No more pinholes. We found many tiny Holes in the liner when we held it up to the light after removing it. I now have moved and have a new pool. You can bet I treated heavily for ants and I treat around the pool every year again. It was an expensive lesson for me to learn.
    33 ft round x 52", vinyl
    Hayward 1.5 hp pump
    sta-rite 2.18ft ,200 lb sand filter
    24500 gal.
    Hayward Salt & Swim3
