Thread: Newly refurbished pool - Can I close or should I wait for acid demand to subside?
    May 2013
    Monmouth County New Jersey
    19
    Hi,
    We just had our IG pool refurbished in July; Coping, Tile and Diamond Brite. My chemicals are in balance but I do find myself adding about 1 gallon of Muriatic acid per week (1 quart every 2 days) in an attempt to keep the PH at 7.5.
    The latest test results (TF-100) are:
    PH = 7.8
    FC= 5.0
    CC = 0.0
    TC = 5.0
    TA = 100
    CYA = 60
    CH = 500
    The CH is somewhat worrisome, my testing with the TF-100 kit has produced readings btw 420 and 500. The company that did the renovation also provided 2 weeks of daily service after the start up and their CH tests ranged btw 390 and 420. The pool store (Anthony/Sylvan) tested yesterday and they got a 409.
    I tested my tap/fill water today with the TF-100 and got a reading of 100.
    Can I close in two weeks or do I need to wait till my acid demand levels off? I typically re-open early June.
    Should testing be done throughout the winter?
    jim
    35,000 Gallon Gunite (circa 1990), Diamond Brite(renovation 2014), Built in SPA, 48 Sqft DE filter, 2HP Pentair single Speed, 300 BTU Heater, Solid Anchor cover, Aquabot Turbo T4RC, CircuPool Si 60+ SWG, TF-100 Test Kit
    Mar 2010
    122
    Re: Newly refurbished pool - Can I close or should I wait for acid demand to subside?
    I would check with the contract and or contractor who did the work. I like to have the pH leveled out before I close my customers. But there are other company's who believe 1 month is ok.
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    38,290
    We recommend closing after the water temp stays below 60 degrees and opening before it reaches 60 degrees ... that is not based on a calendar, that is based on your weather.
    As the water gets cold, the pH will naturally rise. If you are closed down completely, then there is not much you can actually do over the winter anyway.
    May 2013
    19
    Jacob, Jason:
    Thanks for the replies. I spoke to the folks who will be closing the pool and they said that closing on the Sept 22nd would be fine, and that prior to closing I should look to have my TA at 120 and the PH at 7.2.
    They also offer a monthly service (Oct-Mar) where they haul in a large pump, balance if necessary and allow the water to circulate for a few hours. They mentioned that I could do this myself with a smaller cover-type pump and a long hose, but would need to keep the pump running for a few days if I had to add acid.
    Not sure if I am going to do the monthly check, I have never done it in the past 20 years and only had a small amount of scaling in the attached spa once upon opening.
