Thread: First time closing questions...
    May 2014
    Clarksburg, WV
    331
    So I read the article in pool school. I want to make sure i have everything right for when i close..
    I have a 24' AG.
    I'm going to bring to shock lever for a day or so with pump running.
    Turn pump off and drain water below skimmer and return. 6" or so.
    Remove ladder.
    Remove all hoses, drain sand filter, make sure pump is dry. Bring everything I can into the garage. Tarp over the sand filter...leave it outside all winter covered.
    Do I need a pillow under my cover? My cover might have came with a pillow...I haven't even opened it up yet.
    Then once its closed, do I just leave it untouched all winter? Do I need to check FC levels if we have a warm stretch? If I need to add some bleach, how do you do that?
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: First time closing questions...
    Everything above sounds good.
    I'd keep a pillow on it. It will help prevent the weight of snow, ice , and water from having the cover sink to the bottom.
    As for chemicals, I never check it. Adjust pH, bring to shock level, no algaecide, cover it up, and leave it till spring. For the last two years I've waited til the temps were below 60, and then opened when temps were below 60. In both cases I had measurable FC upon opening.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    + 1 to what Smyy said. I do it the same way and have measurable FC when I open.
    Only thing I don't use is the pillow. My cover rests on the water. It has a mesh strip down the center which will allow water to seep through it. 😎
    Jeff
    Casey's Avatar
    SW PA
    10,450
    I have a solid cover and don't bother with the pillow. Never had a problem with my cover sinking to the bottom of the pool.
    SLAM it. Drain it to below the return. Cover it. Forget it. Done.
