Thread: TA test
    acgibson's Avatar
    Aug 2014
    Olney / IL
    61
    TA test
    Still pretty new to the drop testing and just wanted to make sure I am reading the TA test correctly (TF100 Kit). Do you take your drop count from when it first changes from green to red? I notice that if I keep adding drops the red continues to get darker and darker. So do you measure the initial color change from green to red, or when it is very red (seems to be 2-5 drops difference)?
    18,900gal Viking 16'x40' Fiberglass In-Ground Pool w/ Cover Pool Auto Cover.
    WhisperFlo WF-24; Clean & Clear RP 150 Cartridge Filter; UltraTemp Heat Pump; IntelliChlor IC40 w/ IntelliPh Acid Pump;
    Easytouch Panel w/Screen Logic. Kreepy Krauly 820 Robot.
    LaMotte WaterLink Mobile Spin Lab & TF100/K2006 w/ Speed Stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: TA test
    You keep adding drops until it stops changing, then subtract the last one.
    For example: at 10 it turns grey, at 11 it goes pale pink, 12 is pink, 13 is Barbie pink, 14 it's still the same shade of Barbie pink. The 14th drop made no difference, so you subtract it. 13 drops = 130 TA.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: TA test
    This thread is extremely helpful for getting familiar with the tests: Extended Test Kit Directions I'd highly suggest reading through it.
    If you want the short answer for this particular test from that topc and this also applies to other color change tests: Continue adding drops as long as the color continues changing. The final drop, that does not change the color any further, does not count.
    Isolated Spa - 345 Gallons
    acgibson's Avatar
    Aug 2014
    Olney / IL
    61
    Re: TA test
    Got it, thank you.
