Thread: Hayward off-line Chlorine Feeder CL 220 problem
    Sep 2014
    Ottawa, Ontario, Canada
    18
    CL 220 installed in 2009 and initially worked ok. This season, flow does not seem to change with control valve (CV) position. As suggested by Hayward Tech Service, I removed CV, lubricated two O-rings and replaced. However, this did not help. 3 pucks are almost gone (dissolved/eroded) in 2 days when CV is in Fully Closed position as well as in Fully Open position.
    (The problem resulted in high CYA; so, have been using Cal Hypo granular chlorine.)
    I'd be grateful for advise on a likely cause of the problem and how to fix it. Many thanks.
    21K gal, IG plaster new 2010, 3/4 HP Super Pump with 2-speed AO Smith motor w/integrated 2Green timer, sand filter S-244T2, solar heating with HM-4000D controller, Dolphin M400 pool cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Hayward off-line Chlorine Feeder CL 220 problem
    Welcome to TFP!
    Perhaps bumping this thread will let someone see it who can help you (this isn't my area of expertise).
    Nov 2013
    Fort Worth, TX
    114
    I too installed one of these about a year ago when I became a new pool owner and did not know much about this site. You will find the pucks you use in this chlorinator raise your CYA (and quickly) and are a pain in the rear end to use (i.e. Getting cover off). If you have a couple of hundred dollars to spend, install a Stenner pump and inject liquid chlorine. I just did this about a week ago and find it much better than the chlorinator you have. There are tons of threads on this site about these pumps and their installation.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Jaro View Post
    In my opinion you don't want to fix it. The problem with the feeder didn't cause high CYA, use of the tabs did. Fixing it and using tabs will continue to drive up your CYA.
    The problem you have now is that using the cal hypo is driving up your CH (calcium hardness).
    You need to switch to a form of chlorine that does not add additional "stuff" (CYA or CH) to your water.
    Your choices are:
    liquid chlorine (manually added daily or automated)
    Salt Water Chlorine Generator
    How much Pool School have you read? Start with this:
    How to Chlorinate Your Pool
    Support the site
