Results 1 to 8 of 8
Thread: Above Ground Pool - sloping yard...drainage around pool...or retaining wall?
    Sep 2014
    Honey Brook PA
    2
    Post Above Ground Pool - sloping yard...drainage around pool...or retaining wall?
    IMG_0561.jpgWe just recently had an above ground pool installed here in Southeast Pennsylvania. Our backyard has a bit of slope to it where the 24' round pool has been installed. The pool company who installed did a great job of leveling and feather the slope away from the pool...but were confused on what/how to do next. This past week we have had quite a few server thunderstorms which dropped heavy rains two days in a row. We have already had dirt washing away on the slope and settling around the pool. We are not sure if we need to maybe just install some sort of drainage system around the pool...or have the slope taken out more so it is not so steep?..or do we need a retaining wall of some sort?
    I will upload a few pics shortly that we have taken,, and you can hopefully see the slope, and the dirt that has already washed down so far.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP ! Your not too far from me.
    Yes the pictures will help to see what you have.
    If you could add all your pool and equipment info to your sig that would be great. 😎
    Jeff
    Jun 2014
    Apex nc
    95
    Re: Above Ground Pool - sloping yard...drainage around pool...or retaining wall?
    I've got a pretty significant slope. I put in two French drains to route water away from my pool.
    Sep 2014
    Honey Brook PA
    2
    "trying" to attach additional pics
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Users have VERY limited amount of space to attach images, which are stored directly on this site's alloted server storage. Supporters get more storage but the best bet is to upload photos to a photo sharing service such as photobucket and link to them here. It's a bit of a process but there is a good guide on how to do it here: Leebo's Posting Photos Tutorial
    Isolated Spa - 345 Gallons
    Casey's Avatar
    SW PA
    10,450
    You're going to need to address that drainage issue with a french drain. You have a lot of standing water that needs pulled away from the back of the pool.
    Apr 2014
    Jamison PA
    15
    Not too far from me either. The clay soil in SE PA is horrible. I have in IG pool but I actually had my PB put in french drains for my roof runoff for this exact reason. The dirt can take days to absorb the kind of rain we get from 1 bad thunderstorm. I second the french drain!
    Mike, Bucks County PA
    13,500 gallon fiberglass Viking "Triton" pool installed 2013, 1.5 HP Pentair Whisperflo single-speed pump
    Pentair cartridge filter, Pentair IC20 SWG, iRobot Mirra 430 robot
    TF-100 + Speedstir - and so glad I found this site before I started!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It's either the French drain or get some screenings and fill the area in up against the pool to get the water out of there, drain away from the pool. The screenings would work great and they compact well with a hand tamper. Then you could put decorative stone around to dress it up.
    Just my 0.02 😎
    Jeff
