Results 1 to 13 of 13
Thread: Closing pool - how do I winterize the main drain?
    Jun 2014
    New, England
    66
    Hi,
    Can someone please explain to me how to prepare the main drain for the winter? Or don't I have to worry about that?
    I'll be closing my pool before the end of this month, and this is my first time closing. Any help is greatly appreciated.
    26k Gal. 18' x 38' Gunite/White Plaster Roman style in-ground pool, straight Clorox bleach sanitizer, DE filter, TF-100 Test Kit, Taylor Salt Test Kit, Borate Drop test
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Closing pool - how do I winterize the main drain?
    You want to force air through the line that leads to the main drain until you get lots of bubbles for 30 seconds, then close the valve. I'm thinking of getting a large expandable plug to plug all the drain lines inside the pump basket for insurance. I haven't heard of a reliable method to get any RV antifreeze into a main drain line...
    Isolated Spa - 345 Gallons
    Jun 2014
    New, England
    66
    I don't actually have a shutoff valve for the main drain though. I only have the black plastic ball valve that switches between main drain and skimmer drains.
    Do I just forget about clearing water out of the main drain then?
    Mar 2010
    122
    If you can post a pic of the valve.
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    I have been wondering the same thing. I have a three way valve (Jandy). Full skim, full main drain or half of each.
    20 x 44.5 single roman end, ~33,000 gallons, 10 feet deep, garrett vinyl liner, Hayward SwimClear Cartridge Filter, Hayward 2 HP Pump, Cirrcupool RJ60 SWG, Hayward 140k BTU Heater, Polaris 380 with Booster Pump
    20x44.5 (3.5 feet SE, 10 feet DE), IG, Vinyl, Hayward Cartridge (C4030), 2HP Hayward Super Pump (SP2615X20), 2 main drains, 5 returns, Hayward ColorLogic 4.0, Circu Pool RJ60 SWG, Hayward Heat Pro 140K BTU, Polaris 380, Polaris Booster Pump (PB4-60),
    Mar 2010
    122
    So when you go full skimmer that will shut your main drain off.
    Mar 2010
    122
    Which means when blowing out the main drain, after you see the bubbles coming out you turn the valve to turn the main drain off. This airlocks the drain
    Feb 2014
    Central Minnesota
    5,080
    If you only can have either main drain or skimmer (or balance both), set to main drain only first. Blow it out for 30 seconds of full bubbles. Then with blower still going, quickly swap to skimmer only. Blow out skimmer. Then pour RV antifreeze in skimmer line. Cap skimmer line, them more RV antifreeze on top of skimmer with some torn up pool noodle pieces.
    Jul 2014
    Ottawa
    10
    Hi,
    I have a main drain that leads to the skimmer how do I blow that out? I don't have a valve for the main drain.
    Thanks
    Mar 2010
    122
    I make a temp valve out of pvc that can screw into the port inside the skimmer. I tried this last year on a customers pool and worked really good.
    Make sure you thread tape the threaded piece that you screw into skimmer
    Jul 2014
    Ottawa
    10
    Quote Originally Posted by uncfan1573 View Post
    Thats a pretty good idea I will try it out.
    But normally what would you do with the drain? Pour antifreeze and stick foam down it?
    Mar 2010
    122
    Honestly I don't see to many plumbed in that way in ky. In used to blow through it and have a rubber plug ready and remove the blower at the same time plugging it as fast I could. That worked but I wanted a more secure way of doing it.
    Jun 2014
    New, England
    66
    Thanks for the help guys. I'll be using your advice today on my first closing. Wish me luck.
    I think before I open next year I'm going to be installing some much needed plumbing changes to make this stuff easier.
