Results 1 to 11 of 11
Thread: Running into 2 brick walls
    Aug 2008
    North of Tampa FL
    14
    My husband was taking care of our pool but gave up. I don't know what happened, what he added etc. but we ended up with a cloudy pool. Two weeks ago we went to pool store and got water tested. Just for ha-ha's I had him take water to another store. He got different answers. Took it to a 3rd store and got different answers.
    Up to this point he has just done whatever the pool store store tool him to do. The last thing I know he put in there was phosphate remover after he put in some mineral stuff with phosphonic acid in it. Then we put Purifiber in to help remove stuff. And clarifier. And calcium hypo shock and Salinity shock.
    Pool has been cloudy ever since. I told him if it wasn't clear by yesterday I would post a message asking for help. (I was reading Pool Forum for the last week)
    I haven't been able to buy a good test kit because he doesn't want to spend any more money on the pool, the one we have only tests the 4 basics, and Cl only up to 5. I will get a good test kit though, just don't have it right now.
    Today it seemed a little clearer so I started with bleach and liquid chlorine. There were some pink stains on walls and floor but I gave the pool a good brushing and they came off.
    Started with TC at 2.5
    After shocking with liquid stuff
    TC is 12
    TA 70
    CH 300
    Stabilizer 80
    Ph 7.4
    Salt 3200
    I know that's not high enough shock level, even for SWCG but my husband wouldn't let me put anymore in, he thinks it's bad, bleach is poison, etc.
    Filter is off right now. It's been on 24/7 for a week.
    It's dark now so when I turn the light on the pool has a green tinge, it was bluer during the day.
    Right now I'm thinking wait until AM and test the chlorine, if there is none then shock it up to 21 and get a FAS DPD kit in the meantime.
    Suggestions?
    TIA
    14188 Marcite pool. 1/2 hp pump Hayward cartridge filter. SWCG Goldline T-15 Turbo cell. Spillover spa. Birdcage.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Running into 2 brick walls
    I would keep the filter on 24/7. I would keep shocking, your other numbers are in range. See the CYA/Chlorine chart for your shock level...and liquid chlorine is perfectly safe for your pool, bleach is the same thing, sodium hypochlorite. The Pool stores call it "liquid shock". It's fine, as long as you can test your FC with an FAS-DPD test and dose your pool accordingly. The only time liquid chlorine would hurt your pool is if you put too much in for extended periods. Provided your water is properly balanced, normal shocking with bleach or liquid chlorine won't hurt anything.....
    You seem to have a pretty good handle on things, hubby's the skeptic? Maybe he should read the forum? Welcome, BTW!
    Aug 2008
    North of Tampa FL
    14
    Thanks for the reply and the welcome!
    Hubby is definitely a skeptic, that he let me put bleach in the pool was a big step . Little by little I'll convince him.
    The filter is coming back on at midnight.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    There is no reason for him to be skeptical. Let him read some of the posts and look at pictures posted by others who have joined this site with the same issues your having right now witness and see for himself that the BBB method really does work and it does save you money !!
    BUT you need to get yourself a good reliable test kit (see my signature for the link) in order to take control of your pool troubles and be "trouble free"
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Aug 2008
    North of Tampa FL
    14
    I can finally see the bottom of the pool but it still looks green to me. I have some stains, too. I have to go get the water tested. I tried 3 different pool stores for the test kit and every time I said "a test that registers Cl over 10" they looked at me like I had 2 heads.
    [attachment=1:vjsu9gv7]IMG_0302.JPG[/attachment:vjsu9gv7]
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Nice job on the water.
    If you do a search on "stain removal" in the forum you will find some helpful hints and suggestions to help you figure out what type of stains you may have.
    Les
    Helpful Links:
    11,969
    Quote Originally Posted by Jenn_in_FL
    You'll have to order it online, I was never able to locate one here, the local leslies only sells the K2005. You want a Taylor K-2006 or a TF-100. There is an article in Pool School that compares them.... you get more bang for your buck with the TF100, IMHO....plus excellent customer service because Duraleigh is a member here and it's his kit.... plus lots of free advice on testing with it because many many members here use it. The link is on the home page.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    The TF test kits can be found here. As FPM says, a lot of members here use the TF Test Kits.
    They have great customer service and very fast shipping!
    Les
    Helpful Links:
    Aug 2008
    North of Tampa FL
    14
    Got my test kit. Did numbers yesterday. Going to do them again today then run some water up to pool store to compare.
    Pool was nice and clear and blue yesterday!
    Aug 2008
    North of Tampa FL
    14
    Test results
    Mine theirs
    FC 6.5 4
    CC .5 0
    pH 7.3 7.4
    T/A 70 50
    CH 500 225
    CYA 55 100
    Salt ---- 3100
    The CH and CYA are making me nervous. I'll take some water up to the pool builder tomorrow. The little black dot took a long time to disappear. I saw the pic Duraleigh posted on what it looks like so I think I may be closer than them. It was at 80 for a while. I haven't added anything but liquid bleach so I don't think it could have gone up. We've had rain and the kids were in the pool so I think it makes more sense that the CYA went down over going up.
    As for the CH, Tropical Storm Fay is coming so if we get a lot of rain it may take care of the problem for me.
    Their recommendations--Add 1.5 quarts Salinity stain control. Pour 10.6 lbs of Alkalinity increaser into pool.
    Pour 13.7 lbs of calcium harness increaser, 2lbs per bucket.
    I'm not adding anything
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Jenn , Can I suggest shocking your pool right before it gets here. If you have no electricity and you cant run your filter for a few days then you will already have chemicals in the water and you wont have to worry about it.
    If you dont get any or little rain the worst that will happen is you will have to wait for a day or so for the FC to come down if it does rain you'll be ahead of the game
    Les
    Helpful Links:
