Thread: Need help to remove side panel to fix leak.
    Sep 2014
    Oregon
    1
    Exclamation Need help to remove side panel to fix leak.
    Hello all I need help! We have a Dimension one Santiago spa pool and it has a leak, we cannot figure out how to remove panels to fix the leak. It does not show that it can unscrew on the panels in order to remove them.
    Does anyone know about these kind of spa's? We can use whatever help you can provide.
    Thanks
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    Re: Need help to remove side panel to fix leak.
    Can you post a picture so we can have a better idea?
    20,000 Gallons Vinyl 16x32 Inground with Stamped concrete decking. Hayward Sand Filter. DIY Diaphragm pump injection system. K-2006C Test Kit.
    450 Gallons Standalone Acrylic CALSPA 2006.
    Canadians, Get your test kit here!.
