Thread: Choosing a flush mount automatic cover vs. mount under extended coping
    Jun 2014
    leesburg, va
    6
    I am working through the final details on our PB quote. We are planning on a 40x18 in ground, concrete with an automated cover. Cover by Coverstar. I *think* we are going to go with a flush mount track for the cover. The other option is to have the coping extend over the pool and to mount the track under the mounting. I don't like the idea on non flush mount, it would seem to me it would be more difficult to exit the pool, and more chances of hitting your head on the extended coping.... My PB says it costs just a little more to get the flush mount (a few more trips at the coping stage). The only drawback is the cover has a tendency to tear (with flush mount) rather than pull away from the track (under coping lip mount) when too much pressure is applied to the cover. If I keep the water level up, pump off the excess rain water and use a winter cover I think I can avoid this tear drawback. Is there any thing else I need to consider before making the decision? Thanks.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Choosing a flush mount automatic cover vs. mount under extended coping
    I have the under cover track with the overlapping coping and I don't believe I have ever bumped my head against that coping. You simply don't put your head right next to the wall and then raise up your head. You can see what my pool looks like with the pool cover open and closed. You can see the overlapping coping better in this image. Now you can see that we have a ramp so for existing the pool from a ladder perhaps there might be some issue though I still don't think so since it would just be further away from the wall (ladders aren't flush with the wall anyway).
    Nov 2011
    Moberly,MO
    1,010
    You could do a pool in pool design where the cover track is recessed
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
