Thread: Main Drain Screws
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Main Drain Screws
    I believe these screws are aluminium, will the salt in the pool have any effect on them, like eroding or weakening them? Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Jun 2011
    Long Beach, CA
    2,790
    Re: Main Drain Screws
    If they are aluminum then I would think they will corrode either with or without running a SWG. Are you sure they are aluminum, as I find it hard to believe anyone would supply aluminum screws. In any case replace them with known stainless screws.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I tried that but I was told SS screws will not last, I did order some for it, and they look to be aluminum and very light. Maybe that's why they break...just curious.
    Autopilot SWG
    Jun 2014
    Roseville, CA
    345
    Use stainless. That is industry standard for most pool fastener applications.
    Just be sure to tell the clerk they are for a pool so she will remember to double the price!
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I went to Ace Hardware bought 2, put one in the skimmer basket, after a weak showed signs of rusting, I think it was a pour grade of SS.
    Autopilot SWG
