Thread: Tips for installing granite on small outdoor bar?
    Rick H's Avatar
    Jan 2013
    Liverpool, NY
    45
    Hi, this summer I built a small outdoor bar. It is framed in pressure treated wood with a bamboo face. I made it so I can slide it against the house in the winter. Its 66" long,22" deep and 41" high. Its heavy, but I can slide it on the patio without much effort. I want to put on a granite top, and was able to locate a remnant that is 72L" X 25W" X 3/4" thick, so there would be a overhang on the sides and front. It gets full sun, but, will be outside ( and covered ) during the winter months also. I have a solid pressure treated lumber top that is pretty solid. Can I glue the slab right onto the wood? or any other ideas to secure the top? There would not be anything lifting up on the top or anything like that.
    Thanks
    Rick
    Upstate/Central New York. Roman style IG fiberglass pool, 13X33, 8800 gallons, installed July 2012. Pentair cartridge filter, 1 hp Pentair single speed pump. Taylor K2006 Test kit. Went BBB route in spring of 2013, no problems, no regrets!!!!!!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Tips for installing granite on small outdoor bar?
    It should work. Granite is usually held in place by gravity and a couple of well placed dollops of silicone. Th esilicone is an adhesive, but is there more to keep it from sliding as the weight holds it in place.
    Support the site
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    Just a thought - could you add locking wheels to the bottom of your bar to make it easier to move?
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
