Thread: When is it best to switch to TFP
    Sep 2014
    Ossian, Indiana
    3
    Hello All - brand new member to this website. I'm very glad I found it.
    I have used Baquacil for the last two years, but would like to switch to the TFP Method for next year. I am ready to close down my pool for the season and would like to know if I should go through the conversion process before closing or wait until next spring. I'm not sure if it matters or not, but my closing process is very simple - drain the water level to below the skimmer and then disconnect the pump/filter. I do not put a winter cover on my pool as I live out in the country and the winds would tear it to pieces.
    Thanks for any advice!
    26' x 54" AG (18,000 gal), Pentair Dynamo single speed pump
    Sand Filter
    Pool installed May 2013
    Water source is well water with high mineral content
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Re: When is it best to switch to TFP
    Personally I would wait until next Spring to preform the conversion. The addition of rain/snow will add fresh water to your pool, and help in lowering the Baqua levels. The less Baquacil you have in your pool, the quicker the conversion will go. Try to keep any leaves and such out of the water however, as any solids will slow your conversion down.
    I'd also like to welcome you to TFP!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Welcome to TFP!!
    Leebo is the baqua expert so i would say stick with his suggestion
    Support the site
    Sep 2014
    Ossian, Indiana
    3
    Thanks!
    Sand Filter
