Results 1 to 17 of 17
Thread: Emergency help needed!!!!!!!!!!!!
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    just got home from vacation and went to add bleach. Instead, I dumped about a cup of used motor oil in the pool. HELP!! pool calculator doesn't mention this additive. Save the picking on me till the real answers come in, then I'm open for the abuse. thanks
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    38,285
    Re: Emergency help needed!!!!!!!!!!!!
    There are enzyme products that can help remove oils, can't think of the name. Also a scum-ball would help.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    oil will float on the surface
    get an empty soda bottle and use like a skimmer to drain as much oil off surface as possible
    dont turn on pump as it will make it worse
    hopefully richard will respond soon
    earth to chem-geek we need you
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    How about a Wet Vac with an attachment to grab the surface water. The attachment should be about 8 inches long. It would be a slow process if it works. Try a small area and I would recommend moving slowly like your are vacuuming the pool so there is not too much movement in the water. Hopefully this will work. Good Luck !
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2014
    860
    http://www.amazon.com/Scumbug-Oil-Ab.../dp/B003ZJZ8N2
    you could also try a small oil boom that sits above and below the water line to "push" the oil into one area of the pool. Then use suction to clean it out...
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    I bought 4 scumballs and put them in the skimmers. Also bought a bottle of pool first aid since it was suggested on TFP back in 2009.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Yes, Pool First Aide will help, scumbugs, and pig mats will also help soak up oil. Where you using old bleach bottles to store the oil?
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    Peoria, IL
    389
    I think that you are on the right track. Muriatic Acid gets it out of concrete. Don't.know about in the pool. Will dump your ph.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Mar 2007
    San Rafael, CA USA
    12,082
    All are good suggestions. Scooping, scum balls, enzymes, and PIGŪ Oil-Only Absorbent Mat Pad. The good news is that oil and water does not mix so most of it should be easily removable. The rest that does slightly mix in to the water will likely get filtered out as the oil will want to bind to the filter material more than it will want to stay in the water (similar to body oils which filters are designed to remove).
    I would do the physical removal techniques first and leave the enzymes as a last resort for anything left over.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Ouch...can relate to that...hubby bought a new gas powered blower and first time I used it I slung it running right into the pool. Luckily no ill effects for pool or blower. Kinda hard explaining it to the hubs ....:/
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I just want to say good luck, and you are not the first to do this, when I started reading this thread I first thought someone had revived a thread from a couple of years ago, as it reads almost identical to one I have seen on here before.
    Ike
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    A cup shouldn't be too bad, but now that you have some answers.......
    How in the WORLD are bleach and used oil mixed up at your place? I just thought it was crazy land around here sometimes.....
    Essential Links:
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    I should have pulled the label off the bottle. Thanks for all the replies. I put two scum balls in each skimmer and added the pool first aid, no sheen on top of the water this morning,
    Actually it is kinda of a fitting situation. I had to drain the oil in one of the four wheelers before vacation because it had gotten water in it.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by smforte View Post
    I can believe you dropped it in the pool, but how did it not mess the blower up? My wife was afraid I was gonna knock the pressure washer in the pool. Luckily I just fell in. Would've been cheaper to drop the pressure washer in. I can fix a pressure washer. I had to drop $300 on a new iphone.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2013
    East TN
    309
    Ive noticed oil likes to collect in the skimmer as the top layer since it floats. The suction of the pump pulls more water from below the surface than whats on top and leaves the oil in the skimmer. Just scoop it out of the skimmer.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Seems everything is ok. There was no smell or sheen on the water surface yesterday. We got in and wiped out the skimmers and tile line. We threw away the scumballs and added new ones. Tested the water and all the numbers were good.
    Jun 2014
    860
    Quote Originally Posted by Reddogdan View Post
    Glad to hear everything worked out. This is a good thread showing how not to panic and just think the problem through.
    All the VOCs will just burn off. Heavy junk will go to the bottom and get vacuumed out and light stuff will get sucked up by Pig Blanket and ScumBalls.
    You might want to clean out your filter though. Not sure about cartridge filters but you might consider soaking the cartridges in a garbage pail with some kind of pool compatible surfactant to clear any oil out of it.
