Results 1 to 20 of 20
Thread: Pool leak bucket test results in......Help me interpret
    Sep 2014
    Grants Pass, OR
    33
    I did not plug some lines as I just read about this procedure, AFTER doing the tests described:
    This is a 15,000 gal., 16x32 inground pool. Pad does not show any leak and the backwash overflow line is dry. It has been HOT here in southern OR for a month, and solar bubble cover was off for 3 weeks. Even when the bubble cover was on, it seemed to me I was refilling the pool more than the usual.
    Turned off the pump and set bucket on step and filled close to top. Marked inside of bucket. Marked outside of bucket. Ran pool pump for 24 hours. Shut pump off and found pool level had dropped 3/4 inch. Bucket level dropped 1/2 inch.
    Promptly filled the bucket again, close to top and re-marked inside. Re-marked out side of bucket and left pump OFF for 24 hours. Pool level dropped one inch and bucket dropped 1/4 inch.
    Think this tells me that there is a leak.....but NOT in the PVC lines. Am I right? Leak could be in the skimmer, tile/grout, light or eyeball returns. Or in the main drain at the bottom of the pool....or where the ladder goes into the pool floor.
    Any help would be appreciated.
    Mar 2010
    122
    Re: Pool leak bucket test results in......Help me interpret
    So you did plug the lines during the test or didnt?
    Is this pool a vinyl liner? Concrete? Fiberglass?
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    Sep 2014
    Grants Pass, OR
    33
    No, I did not plug any lines. Concrete/plaster
    Mar 2010
    122
    I would plug all the lines then see if it still leaks and get them out of the equation.
    Make sure there isn't any grout and or missing tiles anywhere around the pool/spa. One place to check really good is in the skimmer opening where the tiles meet the skimmer weir. Make sure no grout has come off.
    Sep 2014
    Grants Pass, OR
    33
    Thank you Jacob.....
    Sep 2014
    Grants Pass, OR
    33
    I called the pool builder who did this pool in 1993. He too wanted me to check the skimmer as the prime suspect. I am now pumping out water and in a few hours it will be below the skimmer. I ran the pool for 24 hours on 9/6 and part of 9/7. I shut off the pump mid-day 9/7 and it was off as of 0900, 9/9.
    I re-checked the pool level this a.m. and it had dropped 2 - 1/2 inches from the original test mark. The bucket level dropped 3/4 inch from the original test mark.
    Sep 2014
    Grants Pass, OR
    33
    I dropped the pool level below the skimmer yesterday about noon and did a 24 hour bucket test with the pump off.
    Result was both the pool and bucket lost the same amount of water....about 1/4 inch. I did look inside the skimmer and saw a crack on each side in the grout or plaster, near some tiles. I bought some A and B epoxy putty and will cram some in each crack.....then refill the pool and run a 24 hour test with pool on....and another 24 hour test with the pool off.
    Mar 2010
    122
    Sounds like we found the culprit!
    Jul 2014
    Peoria, IL
    389
    Nice work. I have nightmares about an underground leak.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Sep 2014
    Grants Pass, OR
    33
    Well, maybe the main culprit...but there could be accomplices. Did a 12 hour overnight bucket test with pump off. Pool went down one inch and bucket down one-half inch.
    I am now draining the pool down further to expose the eyeball returns and Polaris cleaner fitting. Maybe I will go lower to expose the light. Will let you know results.
    Mar 2010
    122
    My new guess would be the light niche or conduit that the wires run through
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If the pool leaks down, it will stop itself at the level of the culprit. So you may want to drain to just above a suspect and see if it goes below that one on its own (clearing that suspect). Repeat the process at the level of each suspected leak.
    chiefwej
    Sep 2014
    Grants Pass, OR
    33
    Has licensed pool contractor here today. He agreed the skimmer had gaps and cracks and needed patching. He thought A&B putty was bad idea. He has his own 2-part, the name escapes me. He squeezed a few drops of reagent near the pool light and pronounced it OK. Eyeballs and Polaris fittings do not leak as they are male threads that go into female threads.
    I do not have a ladder going into the pool floor it is a hand rail by the concrete steps. There is rust stain where the rail goes into pool floor. RED ALERT !! He pronounced this the main problem and squeezed some reagent on top of the rust and it seeped into the floor. DOUBLE RED ALERT. He wants me to watch pool level for a couple of more days, pump off..... and call him with results. He thinks rust is from rebar and his plan is to drain the pool some more and jackhammer the rail out.... and keep going until all rusted material/rebar is gone. Then fill with hydraulic cement and replaster.
    Will keep you posted and any comments will be appreciated.
    Sep 2014
    Grants Pass, OR
    33
    I AM DUMB AS A ROCK.....This forum is for above ground.......our pool is IN ground. Sorry to pester and confuse anyone.
    PS I looked 3x and did not see a thread about IN GROUND pools. Did I miss it ?
    Sep 2013
    Connecticut
    728
    Ha -- I've been following your thread with interest, and never noticed that it was in the above ground section of the forum... great powers of observation, I guess
    People seem to put their discussions about leaks in the 'Everything Else' section of the forum -- not a very distinctive title.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Sep 2014
    Grants Pass, OR
    33
    Thanks for moving, mods.....
    Any comments on my 9/12 post about jackhammering out the rail? Another pool guy wanted to use a core diamond circular drill to do the work. Any thoughts on this approach?
    Sep 2014
    Grants Pass, OR
    33
    OK, everything done. Contractor drained pool (relief holes drilled) and pressure tested. No leaks. Rail jackhammered out and some rusted rebar cut out. Hole filled with hydraulic cement and plastered over. Skimmer patched in three places. 2 part Deck-O-Seal applied between concrete patio and coping. DE grids removed and cleaned. Thanks for your comments.
    Sep 2014
    Grants Pass, OR
    33
    UPDATE...So, the pool continued to leak after the contractor left. I did many 24 hour bucket tests with the pump ON and pump OFF. Pump OFF results showed more water loss, considering evaporation rate of about 1/4 inch per 24 hours.
    The problem turned out to be cracks in the skimmer. Now fixed. Bucket tests show only 1/4 inch loss due to evaporation...with pump on and off.
    NEW RELATED QUESTION, please: This is about a 12,000 pool. How many GPD am I losing due to evaporation of 1/4 inch in 24 hours. Think there is a formula, but I can't find it. (Based on my refill output...I guess 300 GPD, but I would like to know for sure)
    Many thanks
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    I think we would need to know the surface area of the pool to even start to formulate an answer.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
  20. Back To Top    #20
    Sep 2014
    Grants Pass, OR
    33
    Oops...........it is 16 x 32.
