Results 1 to 9 of 9
Thread: Question on the TF-100 Test Kit
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    I have been using the test kit religiously for FC and PH almost daily. I am having trouble with the yellow colors on the FC but the PH is pretty good with the color changes, while the FC is very close between 2, 3, 4 (meaning that my eyesight can not tell the difference). Bright yellow of course.
    This morning, about 15 minutes after pouring in 32 ounces of 12.5% liquid chlorine (maybe not enough time for the test to register), and with filter shut off, I also tested for CYA @ 40-50, CC @ O, TA @ 100, etc. If my CC was O and FC was 2.5 based on the extended test directions, does this testing give me a better or more accurate FC test results then the test kit with the 5 drops on each side?
    Was the additional chlorine poured in the pool able to register on the test kit in this small amount of time? With the CYA @ 40, my minimum FC is 3 and Target is 5. I will perform an overnight test this evening to determine how much FC I am loosing daily (if any). I would like to bring my levels up at least to 4 ppm daily.
    My guess is I was @ 2.5 this morning and after adding 32 ounces of 12.5 that this eventually raised my levels to 4.5 based on the calculator. Am I correct or missing something? Or should I have waited at least one hour with the filter running before I tested my levels again. I want to keep my levels between the recommended ranges daily.
    This prompted me to post this after reading a post about the mineralizer system with such low FC levels and cloudy water.
    Thank you.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Question on the TF-100 Test Kit
    I am a little confused about some of the things you are saying. The tf-100 has 2 chlorine tests: FAS-DPD and OTO.
    The FAS-DPD is the one that uses the powder and has a color change from pink to clear. This test is the gold standard.
    The other test (OTO) has a color change that you match (yellow). This test is fine for quick sanity check (is my chlorine in the ballpark?) but is nowhere near as accurate as the FAS-DPD.
    Did you say that you are adding chlorine with the pump off? That is not recommended.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I would recommend to let the chlorine mix with pump running for 30 mins or so, then test.
    Not circulating the chlorine through the water can result in "hot spots" or, areas where the chlorine concentration is higher than others.
    The OTO test, the yellow one, is not as accurate at the FAS-DPD. I find some of about 1.5-2 ppm difference when I compare them.
    I agree with Svenpup, use teh OTO for a ball park and use the powder test to know the real story.
    Divin Dave,
    Catanzaro's Avatar
    Jul 2014
    2,256
    Quote Originally Posted by svenpup View Post
    Yes, this is the test I was referring to, the one with the powder being more accurate.
    I just wanted to clarify that the FAS-DPD test is the more accurate test. This answers my question.
    No, I run the pump for about 30 minutes while adding the chlorine.
    I have been adding chlorine in the morning with the pump running. The pump runs for about 30 minutes and then is shut off. This morning it was about 15 minutes. Then I shut off the pump and tested the water. I was in a little bit of a hurry this morning. Then the timer goes on @ 12 p.m. and shuts down @ 7 p.m.
    Should I purchase extra pins and maybe break down the cycle about 2 hours in the morning and 5 hours in the afternoon? 2X daily? This may be better. This way when I add the liquid chlorine it circulates for about 2 hours. I do not believe the test registered this morning and will find out this evening about 7 p.m.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Catanzaro View Post
    This is the way I run mine, but with my Stenner pump the chlorine is being added constantly anytime the pump is running.
    Support the site
    Catanzaro's Avatar
    Jul 2014
    2,256
    Unfortunately I have an empty frog system now and hopefully the Stenner Pump can fit perfectly in that spot. I am assuming it is some sort of slow drip metered way of adding liquid chlorine. For now I do not mind adding it manually.
    Jun 2011
    Long Beach, CA
    2,790
    You might switch your testing time, test and add chlorine in the evening while the pump is running if you can.
    Catanzaro's Avatar
    Jul 2014
    2,256
    Sometimes I can add the chlorine @ night, but my schedule changes a lot. I like to get in a routine and stick with it.
    I just went out and tested the levels. This morning I added 32 ounces and in the afternoon I added another 16 ounces of 12.5% liquid chlorine. I performed the FAS-DPD and after the heaping scoop & swirl to mix I added 7 drops before the water turned clear, multiplied by .5 for a FC of 3.5 ppm. It was a hot day today in NJ about 91 with humidity. Tested now as sun is down and clouds have covered everything and raining. Will be dark in a little bit.
    Based on the calculator I raised my FC level about 3 ppm today (minus) what I lost during the day possibly meaning that I was low on chlorine before the first 32 ounces (hard to tell).
    Should I add more this evening to bring the levels up to 5 ppm? Or should I test in the morning and then add enough to bring me back up to the 5ppm.
    Additionally I went out and purchased some pins for the Intermatic Timer so I can have the filter run in the a.m. for about 2 hours (to circulate the new chlorine daily) and then in the afternoon for about 5 hours, therefore giving me 2 run time cycles to match my schedule. It is difficult for me to keep the schedule for the evening.
    Thank you.
    May 2014
    Franklin, NC
    9,184
    There is a learning curve as you get a handle on the pulse of your pool. The target is just that, a target. If you find the sun is burning up your FC you can aim just a little higher - you always want to keep above the minimum.
    My schedule is a bit funky also and I may be out of town for three to four days to a week or ten days. For that reason I added the Stenner pump. With my usage and tank size I can be goen for a little over three weeks before the tank runs dry.
    HERE is the thread that shows my install, including a few photos. I'm not sure if there is a port on your Frog to use as an injection point, but PVC work is easy and you can always cut it out and add a "T" like I did.
    The other options are a SWCG and a Liquidator. All three methods add chlorine continuously as your pump runs. Do some searches and decide which is best for you and your pool situation.
    Support the site
