Thread: Spa through wall leak under spa overflow ledge
    missing's Avatar
    Aug 2014
    Highland Village, TX
    37
    Spa leak down at the check valves was resolved. The spa leak through the wall from what is under the spa overflow is not resolved. How difficult is it to removed the spa overflow sandstone ledge and re-install with no gaps in where ledge meets spa edge. what is the best type of mortar or substance to use to lay the sandstone. Is this something a novice bricklayer/stone guy can perform or too many unknown skill required? Thanks to the group.
    Pool Built 2008, IG rectangular + round spa 15330 Gallon, quartz color finish, with spa, Jandy CL460, 4 Cartridge filter Unicel C-7468, 2 HP motor Centurion Pool pump, Booster Pump Centurion 3/4 HP motor, Pentair booster pump LA01N, LXI400N pool heater
    SWG Aqua Pure PCL 1400 Chlorinator not working
    Apr 2013
    Sacramento, CA
    2,769
    Re: Spa through wall leak under spa overflow ledge
    From the pictures I'm not totally sure you have a leak. What is your CH?
    Before tearing all this out I'd go get a couple of repair bids. They are free and you get to hear what some pros think.
    I'd first look at ways of stopping the leak inside the spa with either some caulk or cleaning out the grout under the stone spillway and replacing with some new cement grout. That's where your initial failure is anyway.
    Beyond that it gets tricky. To Remove and repair you have to take off a lot of stone and replace. One can do it its just slow because you don't want to damage the stone you are removing.
    missing's Avatar
    Aug 2014
    37
    Thanks, i have thought of that route to replace the grout/mortar under the stone ledge and on the top where the spillway butts up to the top cap. Then we have a solid stone set, i am not that anxious to demo and repair all the stone on the pool side of the spa. If i can detach and reset the stone spillway and resolve the leak, that would be great. I have a call into a pool company for their assessment of the issue.
    I had patched under the spa spillway spa side with epoxy in what i thought was a hole under the ledge. Did not resolve.
