Thread: Is SWG compatable with concrete/aluminum?
    Pipe Rat's Avatar
    Jun 2014
    St Louis, MO
    21
    Hey guys I am building a DIY inground vinyl liner pool and am at the stage where I am ready to install the coping and liner track. I really want to pour a cantilevered concrete coping and do not want to seal it. I do not want the maintenance or the look. Should I be concerned about using concrete coping with a SWG?
    On the same subject I think I would prefer aluminum liner track as opposed to PVC for durability. I have the same question here, which material should I use with a SWG?
    Thanks
    Jul 2014
    Peoria, IL
    389
    Re: Is SWG compatable with concrete/aluminum?
    I have concrete and aluminum and have no issues. I would add some sacrificial anodes to your ladder and maybe an inline one that attaches to the bonding wire down by the pump. A lot of guys will say that you don't need them but mine get eaten up at 3200ppm of salt. 3 years old and I will probably replace next year. I figure for $20 better rating that than my equipment.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Mar 2007
    San Rafael, CA USA
    12,082
    With aluminum, you should most certainly have a sacrificial zinc anode attached electrically to it and the anode preferably buried in moist soil. That should help protect aluminum that is immersed in the water. However, if you have aluminum railing for a pool cover and is exposed to splash-out, then you need to wash it off regularly or else it will look like the photos in this post.
