Thread: Issue number 4, knob band assembly stripped, how to fix?
    Feb 2014
    dfw tx
    67
    So before I can fix the shaft seal that might be leaking and after the tons of other stuff i've done already and the fact that the pool hasn't been run in 6 days and counting now. The knob on the band assembly gets stripped out!! kept turning and turning so I grabbed a pair of pliers to try to pull it off and that didn't work. What another way to remove it or should I just replace the pump already.
    Item 20 in pic
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Issue number 4, knob band assembly stripped, how to fix?
    Do you have a Dremel type tool? using a thin cut-off wheel, make two slits in the knob shaft. Then pull the knob off the insert. You should then be able to turn the insert with pliers.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Just to verify, the bolt head on the other side of the band clamp isn't turning when you turn the knob?
    There's really nothing special about the bolt arrangement you have there. For a couple of bucks at a decent hardware store you could get a stainless steel bolt, nut and washers that would replace all those parts. You really don't need a knob unless you want one.
    As Charlie_R said, a Dremel tool would cut the plastic part of the knob off and get you good gripping access to the insert nut. If that doesn't work, you could cut the head off the bolt on the other side with a Dremel or hack-saw.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Sep 2014
    Mass
    13
    What is the condition of the water in the pool after no running it for almost a week? Not sure what type of pump you are running but maybe a new pump would be easier in the long run. If the water is getting nasty then how much money are you going to spend in chemicals to get it back to where it needs to be..
