Thread: Pressure Gauge with above ground pool
    spylab's Avatar
    Jun 2014
    Fort Worth, Texas
    20
    My sand filter came with an explanation that flow meters are the least accurate way of determining when to backwash. I would still like to have one because I like doing things by the numbers I saw a link to My Pool Yard on another post (sorry don't know how to link) and it says all I need is my pipe size. I know I have 1.5 inch but it is the flexible stuff for above ground pools. These meters mention PVC. Would they or any other reasonably priced meter work with my set up? Thanks!
    5,400 gal, AG PVC coated kevlar like scrim liner, Advantage 1.5 HP with 19" Sand Tank
    Krystal Clear Ozone & Salt Water System, Taylor TF-100 and K1766 Salt Test
    38,521
    Re: Flow Gauge *** on with above ground pool
    Just backwash when the pressure rises 20-25% over the clean pressure. No need to know the actual flow rate. A pressure gauge is a lot cheaper than a flow meter.
    spylab's Avatar
    Jun 2014
    Fort Worth, Texas
    20
    Shows what I know LOL I don't have a pressure gauge either. I think I was using the two interchangeably. Since my filter does not come with one is there an aftermarket option?
    38,521
    Re: Pressure Gauge with above ground pool
    Well, you can add pressure gauge anywhere between the pump and the filter. They are usually on the top of the filter ... odd yours does not have one.
    So you can add a PVC Teed between the pump and filter and screw in on of the gauges.
    spylab's Avatar
    Jun 2014
    Fort Worth, Texas
    20
    Much better than converting the entire plumbing to PVC Thank you!
