Results 1 to 8 of 8
Thread: pH Testing
    Aug 2014
    Monticello MN
    38
    pH Testing
    Hello to all. I use the Taylor K2006, but I still have the cheap OTO tester I had B/4 I got the Taylor. Regarding pH, the tests "appear" to be the same as far as matching color shade. Is it the quality of the Taylor reagents that make the difference? I'm not considering switching back, lol, just curious. Thanks.
    Blaise - 24k gal, IG vinyl, 1.5 HP Centurion pump, Sta-rite System 3 sand filter, Taylor K-2006 test kit.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: pH Testing
    The K2006 should have a drop test for FC, where you put powder in the sample, swirl, and then add drops til the pink color disappears. The K2005 does have a pink color-matching FC test, is that what you're using?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: pH Testing
    Quote Originally Posted by Melt In The Sun View Post
    He is asking about the pH, not FC.
    Support the site
    Aug 2014
    Monticello MN
    38
    Re: pH Testing
    Thanks for the responses, and yes, I was referring to pH.
    38,271
    Re: pH Testing
    The Taylor pH reagent does have some additives to attempt to negate the affects of chlorine on the test. Other brands may not or may not do it as well.
    Aug 2014
    Monticello MN
    38
    Re: pH Testing
    Thanks Jason, I figured it was something like that.
    May 2014
    Franklin, NC
    9,184
    Re: pH Testing
    Add one item to my "I learn something every day".
    Support the site
    Jun 2014
    860
    Re: pH Testing
    The cheapo PoolMaster 5Way pH test requires adding one drop of their solution #4 (sodium thiosulfate) to eliminate FC prior to adding 5 drops of the pH reagent.
    Taylor pH reagent has the FC sequestrant built into it.
    Both tests yield similar results in my opinion.
    I use my cheapo PoolMaster kit for daily, testing with the OTO drops just there to tell me I have FC present (the OTO color scale is worthless and inaccurate).
    I use my old GuessStrips for making creative stick sculptures which I then sell on the roadside for $100's of dollars to unsuspecting tourists....
