Results 1 to 9 of 9
Thread: New member that doesn't know anything about AGP
    Sep 2014
    Dallas
    36
    Hi everyone I just joined and I don't really know anything about AGP . I also ordered our first AGP a 16'X32'X52" Intex ultra frame / saltwater system and any advice would be greatly appreciated for sure.
    Best regards
    Yachtnutz
    Sep 2014
    Dallas
    36
    Getting ready to start the ground work
    Hi I'm getting ready to start the ground work for my 16'X32'X52" intex pool , and I have a couple of questions do I use sand and extruded boards and then the Gorilla flooring. I've been reading some say use sand and some disagree because it will shift . Any advice would be greatly appreciated !
    Thank you
    Yachtnutz
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: New member that doesn't know anything about AGP
    Sand will shift and be washed away out from under your pool. Dig down to level. You can use a bit of sand (say 1/2") to smooth the dirt out but no more. I was very careful and still had some sand wash out such that there is a low spot where the rainwater was running out from under the pool.
    Some also use crushed rock - forget what it's called - which apparently compacts and stays in place.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Sep 2014
    Dallas
    36
    Do you think a concrete pad would be the best way to put up my 32'x16'x52" intex just trying to do it right the first time ?
    Yachtnutz
    Jun 2013
    East TN
    309
    I have lime under mine. We also heard that sand would wash away. Whatever the case the lime is still there after 10 years +.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    jmcdtucson's Avatar
    Jun 2014
    317
    A level concrete pad would certainly be the easiest. But it's expensive and not necessary.
    The most important is that it's level within about an inch and that you dig down to level rather than trying to bring in material to build up.
    Just search for the words
    intex install level
    and you'll get a bunch of threads on installs with lots of tips.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    We have 4 yards of sand under our 20' intex. It hasn't washed away. However, It IS contained by landscape timbers.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    jmcdtucson's Avatar
    Jun 2014
    317
    Our sand is contained by 2x6's and some did wash away. So your mileage may vary. It might depend on the surrounding gradient - our pool is in kind of a low spot on a relatively steep grade (1 ft. per 22 feet) and right where water gathers from either side and wants to run thru so that water really wants to run underneath our pool
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    I used the "screenings", we call it "crush" here. It has been great except for areas where it has been exposed to the rain - it has washed out. However anywhere it is covered, like with tarp, it's solid. Glad I did it. I plan on filling in the washed out spots (I have quite a bit left over) and covering it with landscape rock.
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
