Thread: Started raining while draining, should I be worried?
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I'm in the middle of draining 14,000 gallons out from from my pool, which holds 21,000, to drop my high CYA and CH. It has not rained in a few days, but it just started raining. Am I at risk of my pool floating out of the ground?
    I will have about 7,000 gallons and 22 inches of water by the end of this, which is about 2 hours away.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    38,370
    Re: Started raining while draining, should I be worried?
    How deep is your ground water? Around here it is measured in 100s of feet, so a little rain does not matter.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Not to high. Nearest drainage canal has standing water, and it's elevation is about 10-15 feet lower relative to us I believe. Unless I go and dig a hole in the yard, I won't know the true level.
    J.R.
    20K IG gunnite pool
    Cartridge filter
    Oct 2013
    Chapin, SC
    1,141
    Whatever rain is going in your pool just adds a little extra weight that should help keep your pool from floating. And may lessen the amount of water you need replace.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    It's not a problem anymore, I have the pool filling back up. It even stopped raining. It was down pouring pretty good while it was draining, which had me concerned.
    Thanks everyone
    J.R.
    20K IG gunnite pool
    Cartridge filter
