Thread: Getting rid of algae stains
    The night before we left town for vacation, we noticed a pretty significant leak in one of the pipes. With no other alternative, we called the pool co to repair and turned off the pump so that it didn't run dry before the leak was repaired.
    When we got home a week later, there was, as expected, some algae growth ( it was about 5 days until it could be repaired due to the Labor Day weekend). Most of it brushed off the sides easily and the water is now back to clear sparkling blue. However, there are still some green stains on the side.
    Is there any way to dissolve these stains? Do I just need to brush harder? Or is it just a matter of time and letting the chemistry do its work?
    I'll add that we have a SWG.
    Thanks for any help!
    inground gunite, 18x38 freeform, 3'-9' w/ diving; 3M caymen green/blue blend; Pentair 2HP whisperflo; + aux pump for water feature; SWG; Rheem heat pump; Polaris 380; Pentair TR 100 sand filter; silverlake flagstone coping/broom finish concrete deck; NPTG Aztec cobalt tile; 18" bond beam wall with water feature
    38,305
    Re: Getting rid of algae stains
    How did you clear up the algae? Did you follow the ShockLevelAndMAINTAIN Process? Usually maintaining the elevated FC levels and brushing will remove organic staining.
