Results 1 to 7 of 7
Thread: Amount of chlorine gereration from SWG
    Oct 2013
    Oklahoma
    50
    Not an important question but one mostly of interest. I have a Jandy SWG for my 15000 gal pool. I just wondered how much actual chlorine they generate in like 12 hour period. Im not really looking for exact numbers. Would you think it would be equal to a few cups of 8% bleach per 12 hr period? One other thing, is there any negative consequence to running the SWG at 100% for a period of time vs a fraction. It just seems to me that i wouldnt have to run my pumps as long, less electricity and less wear
    13000 gallon pool, SWG, DE Filter, 2 sheer descent waterfalls, built Jan 2014
    38,268
    Re: Amount of chlorine gereration from SWG
    You need to know the specific model number of the SWG (cell size) to calculate the chlorine output.
    It makes no difference if you run the SWG at 25% or at 100% for 1/4 the amount of time. You are correct that you will save money on electricity by running the pump less and the SWG at a higher % ... but the "wear" on the SWG is the same either way.
    Oct 2013
    Oklahoma
    50
    Attached is photo of the model number Please be aware I'm not looking for exact numbers but just some correlation as to if I was just adding bleach instead. I love the SWG system and just wondered how it compared.
    Jun 2011
    Long Beach, CA
    2,781
    That cell can put out 1.25 lbs. or 20 oz. of chlorine a day which is equal to 20 ppm of chlorine in your 7,500 gallon pool. It would be equivalent to 228 oz. of 8.25% bleach. You can use PoolMath to calculate everything you want, see my signature.
    Oct 2013
    Oklahoma
    50
    Actually about 15000 gal pool but thanks so much on this info. So almost a gallon of bleach every 12 hours. That's a lot of bleach😃. Glad it's doing its job!
    38,268
    So is the signature shown in the forum not your pool? Could be a glitch from the software change.
    Oct 2013
    Oklahoma
    50
    Yeah. Looks like I have someone else signature. I'll work at correcting that
