Results 1 to 8 of 8
Thread: Help Needed
    Help Needed
    OK, have been fighting algae for a week now and looks like I have finally won, the water is almost crystal clear again!!
    The pool is an Intex Easy Set 14 foot (9500L/2500g) pool.
    My question is, how do I get the fc level to go back down, it is currently at the shock level 10 and holding.
    The levels are:
    FC 10
    pH 6.3
    CYA 0
    Any suggestions on what I can do so I can get back in the pool?
    Thanks
    Sharkline 18x33 54"AG, Hayward 1.5hp Perflex D.E., TF-100 test kit
    Finally....a pool of our own!
    Re: Help Needed
    Welcome to TFP!
    If your CYA level is really 0 then the FC level will come down very rapidly during the day and will get close to zero in only a couple of hours.
    Again, if the CYA level is really 0, you should add some stabilizer/conditioner/cyanuric acid/CYA to the pool. The normal goal for CYA is between 30 and 50.
    If your PH is really 6.3, it is dramatically too low and is causing damage to the vinyl liner. Perhaps that is really a typo? The standard PH test will only read down to 6.8. You should verify your PH reading and if necessary raise the PH to at least 7.0 right away.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Help Needed
    Why do you have no CYA in your water? CYA helps your chlorine survive the hot sunny days.
    You should be able to get into it now ...........
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    30,415
    Re: Help Needed
    Take heed what Jasonlion has said and raise your pH up into the mid 7's ASAP!
    Do not worry about your chlorine...it's coming down on it's own.
    Re: Help Needed
    According to the calculator I have to add 85 oz by volume or 89 oz by weight of Borax to raise the PH to the correct level.
    How do I measure that if I do not have a scale to measure the weight?
    Re: Help Needed
    Quote Originally Posted by tbay2005
    use volume! 8 oz per cup, so 85 oz is 10.5 cups.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Re: Help Needed
    Sorry for being a pain but you say an fc level of 10 is safe to swim in? You won't lose any skin or anything like that?
    Re: Help Needed
    What FC level is safe to swim in depends on your CYA level. With CYA at 0 you shouldn't swim with 10 FC. With CYA at 20 or higher swimming with FC at 10 is just fine.
    Extremely high FC levels relative to your CYA level tend to damage hair and bathing suits, skin is just fine.
