Thread: iq900 install today
    Sep 2014
    Slidell
    1
    iq900 install today
    Hey guys i installed the iq900 system to my pool today. Everything seemed to go ok so far. panel installed, vs pump installed with switches 1 an2 on.
    what do the dip switches on the panel get set at? Also trying to run it in service mode and the relay does not kick on to give power to pump. Still not seeing internet connection as I have a blinking yellow light. so multiple things going on. Long day with cleaning out the pool also. Will start fresh tomorrow just looking for some advice. Thanks
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: iq900 install today
    Welcome to TFP!
    Though I have a Pentair Intelliflo VF pump, my automation system is the Pentair IntelliTouch so I'm not able to help you. I do know that going into service mode just powers the pump but does not turn it on. Check the panel on the pump and turn it on manually there or see if there is power to it -- you can't just see if the pump goes on to determine power in service mode.
