Thread: what kind of return fitting for floor return?
    ok so I have a pool that has a standard return on the floor of the pool. I was hoping we could fit an actual floor return in the liner change but everything we found was for gunite pools. What do you recommend for installing down there that won't stick up and stub toes. Pool is only 5 feet deep.
    heres a picture just for reference. Its just a standard wall fitting except its in the floor for some reason. there are 4 other returns in the walls of the pool (they just haven't been cut out yet)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: what kind of return fitting for floor return?
    I'm not sure what size fitting you have down there or what will fit and be somewhat recessed, but something like this would be nice. http://www.poolsupplyunlimited.com/A...FcRzMgodBjUAXg
    Isolated Spa - 345 Gallons
